BS2 and Smoke Detectors — Parallax Forums
WavemanWaveman Posts: 20
edited 2007-06-05 16:31 in BASIC Stamp
Has anyone every tried to interface a smoke detector to the BASIC STAMP BS2? Either photoelectric or ion type?
WaveMan
  • wurxwurx Posts: 10
    edited 2007-05-31 12:10
    3 things come to mind.
    1 - if you just want to see if it is registering an alert, you could easily get a signal from the piezo speaker.
    2 - Using a basic stamp in conjunction with or instead of a smoke detector is unreliable and dangerous.
    3 - Experiment, learn, explore...yes. Use in real life, ABSOLUTLY NO!
    Good luck, have fun.
    edited 2007-05-31 14:29
    This is a duplicate thread. Post replies only to the original thread at the following link.
    http://forums.parallax.com/showthread.php?p=653298
  • WavemanWaveman Posts: 20
    To Wurx,
    Thanks and not using BS2 in place of a·''real"·smoke detector. Just an application that will go in a test equipment rack in an industrial environment to·detect sever equipment overheating and potential fire.
    WaveMan
