B&W grapics driver — Parallax Forums
B&W grapics driver
boeboyboeboy Posts: 301
edited 2007-06-04 20:31 in Propeller 1
Can some one post a good black and white grapics driver i can not seem to find one.
My computer, http://forums.parallax.com/showthread.php?p=630466
    edited 2007-05-24 02:09
    Is there a reason you can't just set your palatte to black and white?
    Paul Baker
  • Dennis FerronDennis Ferron Posts: 480
    edited 2007-05-24 03:01
    Paul Baker (Parallax) said...
    Will that get you 1 bit per pixel, or will it use 2 bits per pixel and only use two of the four colors?
    edited 2007-05-24 03:06
    Depends on which driver you are using, most of them are 2 bits, but the 512x384 driver is 1 bit.
    Both methods work.
    Paul Baker
  • boeboyboeboy Posts: 301
    edited 2007-05-25 19:23
    Yep the reson is I do not know how toconfused.giflol.gif·. So how do you do that for the standard driver that comes with the IDE?
    Post Edited (boeboy) : 5/25/2007 7:31:56 PM GMT
    edited 2007-05-25 19:26
    Which one?
    The TV or the VGA?
    And do you want 1, 2 or 3 bits of black and white?
    It's no biggie to post the changes, just let us know what you want.
    edited 2007-05-25 19:29
    I want·it to be sent to the tv and in·the mode that takes the least stack I do not know that much about how the data is sent to the TV so I am very thankful to all the people here.
    Post Edited (boeboy) : 5/25/2007 8:05:46 PM GMT
    edited 2007-05-25 21:50
    Ok, so it's one bit color then, single buffered at a moderate resolution, say 256x192. That's 6k of ram, plus a few misc longs for the Parallax driver. This does cause problems with text though! Planning to just use the Parallax graphics library? If so, that will work nicely.
    That mode will give you about 32 x 24 text. Are you looking for just text, or graphics too?
    edited 2007-05-26 00:44
    If you want just text, you won't need much memory at all, even with color, because the TV text driver gets pixels from the character ROM which doesn't take up RAM.
    edited 2007-05-26 20:56
    This is for my computer(see my signature)all I need is some text and some boxes.
    Just use a color palette that is appropriate, use Graphic_Palette.spin in you examples folder to determine the correct values.
    Paul Baker
