SD interface — Parallax Forums
SD interface
JTCJTC Posts: 60
edited 2007-05-24 04:44 in Propeller 1
·Where can I find· sdspifasm.spin and interface wiring ?
thanks smile.gif Jim
    edited 2007-05-24 02:21
    Remember this? (You are in this thread) [noparse]:)[/noparse]
    http://forums.parallax.com/showthread.php?p=643801
    It has the wiring diagram for the SD.
    You should be able to find the SD drivers in the Propeller Object Exchange.
    I believe current is 1.5 (check Storage)
    ww1.parallax.com/Default.aspx?tabid=65
    Oldbit
    The comments and code above are proof that a million monkeys with a million propeller chips *could* write Shakespeare!
  • JTCJTC Posts: 60
    edited 2007-05-24 02:52
    I knew I saw this thread but couldn't find it.
    What is the driver name. I have looked.... I'm sure I am just
    overlooking it.
    Thank you very much for your response.
    Jim
    edited 2007-05-24 04:16
    The name is "FAT16 routines with secure digital card layer"
  • JTCJTC Posts: 60
    Thanks Mike, that will do it.
    Jim
