You should be able to find the SD drivers in the Propeller Object Exchange.
I believe current is 1.5 (check Storage) ww1.parallax.com/Default.aspx?tabid=65
Oldbit
The comments and code above are proof that a million monkeys with a million propeller chips *could* write Shakespeare!
I knew I saw this thread but couldn't find it.
What is the driver name. I have looked.... I'm sure I am just
overlooking it.
Thank you very much for your response.
Jim
http://forums.parallax.com/showthread.php?p=643801
It has the wiring diagram for the SD.
Oldbit
overlooking it.
Jim
Jim
