Servo question — Parallax Forums
Servo question
mynet43mynet43 Posts: 644
edited 2007-05-22 22:19 in Propeller 1
I've seen several references recommending a 4.7K resistor between the Propeller pin and the servo control signal. This is recommended in the support code (servo32.spin), etc.
My question is:
I believe the servo control signal is a high-impedance, input-only signal. If this is the case, then there should be no possibility of the servo signal affecting the Propeller pin, even with a direct connection.
Would someone please clarify the need for a current limiting resistor?
Thanks for your help!
    edited 2007-05-22 20:14
    The reason for the recommended resistor is the possibility of electrical interference on the line.
    Paul Baker
    edited 2007-05-22 20:40
    The other piece is that accidents do happen. I have a Protoboard with mixed +5V and +3.3V sensors, some attached by jumpers. It's safer to have series resistors in those Propeller leads that can tolerate them, just in case I hook things up wrong. If I had some other type of wiring or a +3.3V only system, I'd probably dispense with them.
  • mynet43mynet43 Posts: 644
    Thanks all.
    That's kinda what I thought.
    It's to protect you from yourself.
    Makes sense now...
