Servo question
![mynet43](https://forums.parallax.com/uploads/userpics/680/nC6JG6W1TRY21.jpg)
I've seen several references recommending a 4.7K resistor between the Propeller pin and the servo control signal. This is recommended in the support code (servo32.spin), etc.
My question is:
I believe the servo control signal is a high-impedance, input-only signal. If this is the case, then there should be no possibility of the servo signal affecting the Propeller pin, even with a direct connection.
Would someone please clarify the need for a current limiting resistor?
Thanks for your help!
My question is:
Paul Baker
That's kinda what I thought.
It's to protect you from yourself.
Makes sense now...
