Need less than 3.3v
I am planning to use a scp1000 on a project and it runs best at 2.7v can I use a diode in series from a 3.3v regulator to get close?
- Stephen
- Stephen
-Rule your Destiny-
--Be Good. Be Bad. Be Provas--
The hellinic (Greek) robots portal: Greekbotics
Many Projects and Schematics by the users·and also robotic news
(Translate using babelfish)
It will be better off with a voltage regulator. There are some nice low dropout, low quiescent current 2.7 volt fixed regulators around. I like the LT1761es5-2.7, at 20 uA quiescent, and there are others at down to 4 or 5 microamps quiescent.
Tracy Allen
www.emesystems.com
Or use the 317.
