Need less than 3.3v — Parallax Forums
Need less than 3.3v
FranklinFranklin Posts: 4,747
edited 2007-05-21 08:10 in General Discussion
I am planning to use a scp1000 on a project and it runs best at 2.7v can I use a diode in series from a 3.3v regulator to get close?
- Stephen
  • Tricky NekroTricky Nekro Posts: 218
    edited 2007-05-20 15:45
    Use an LM317... First use a trimmer-pot and get the desired voltage... then replace it with resistors and you 're jet!!!smilewinkgrin.gif
    -Rule your Destiny-
    --Be Good. Be Bad. Be Provas--
    The hellinic (Greek) robots portal: Greekbotics
    Many Projects and Schematics by the users·and also robotic news
    (Translate using babelfish)
    edited 2007-05-21 01:27
    It depends on the current. True, a silicon diode has a forward voltage drop of 0.6 volts, but that is only at a current of 10s of milliamps. That sensor claims a current drain of only 3.5 microamps, and the forward drop of a diode at that current will be much much less than 0.6. It may be that the sensor draws pulses of current when it actually makes a measurement, and often the last thing you want on one of these sensors is a changing voltage at that very instant.
    It will be better off with a voltage regulator. There are some nice low dropout, low quiescent current 2.7 volt fixed regulators around. I like the LT1761es5-2.7, at 20 uA quiescent, and there are others at down to 4 or 5 microamps quiescent.
    Tracy Allen
    www.emesystems.com
    edited 2007-05-21 01:59
    Here's my idea (attached.)
    272 x 152 - 2K
  • Dennis FerronDennis Ferron Posts: 480
    Just configure an op-amp as a voltage buffer (negative tied to output, positive tied to resistor-divider) and use the output of the op-amp as a power supply.
    Or use the 317.
