PCA8565 Code for BS2 (I2C)
Does anyone have any information if this will work with a Basic Stamp on a I2C Bus? PCA8565, Philips Semiconductors, Real time clock/calender. If so is there any sample programs?
Thank You
Guido
Post Edited By Moderator (Chris Savage (Parallax)) : 5/17/2007 12:51:13 AM GMT
Thank You
Guido
www.parallax.com/dl/docs/cols/nv/vol3/col/nv79.pdf
www.parallax.com/dl/docs/cols/nv/vol3/col/nv85.pdf
www.parallax.com/dl/docs/cols/nv/vol5/col/nv115.pdf
There is a program for the PCF8583 (linked below). This is is also an RTC and the code may be similar. At least this would give you some ideas on talking to your chip if you compare the two. I hope this helps. Take care.
http://forums.parallax.com/showthread.php?p=534240
Chris Savage
Parallax Tech Support
