DC to DC Step Up ???
Hi all,
can someone describe what a dc to dc step up circuit is.· From what I can tell from this link, this circuit takes in a 1.1v upto 4.5V input and generates a 5V output.· Does this mean I can use real small volt batteries in that range and still get 5v out of this puppy?
http://www.sparkfun.com/commerce/product_info.php?products_id=8290
thanks in advance
"any small object, accidentally dropped, goes and hides behind a larger object."
ALIBE - Artificial LIfe BEing. In search of building autonoumous land robot
thanks in advance
BUT, that does not mean you can draw several amps from the high side with only a watch battery on the input side!
As a rule of thumb: input volts x input amps = output volts x output amps x .80, your mileage may vary.
Cheers
Tom Sisk
http://www.siskconsult.com
Equipped with his 5 senses, man explores the world around and calls his adventure science
-Edwin Hubble
Also a good 2 part series in a Nuts n Volts artical, "High voltage PIC" in the September & October 2006 issues
