DC to DC Step Up ??? — Parallax Forums
ALIBEALIBE Posts: 299
edited 2007-05-05 03:57 in General Discussion
Hi all,
can someone describe what a dc to dc step up circuit is.· From what I can tell from this link, this circuit takes in a 1.1v upto 4.5V input and generates a 5V output.· Does this mean I can use real small volt batteries in that range and still get 5v out of this puppy?
http://www.sparkfun.com/commerce/product_info.php?products_id=8290
thanks in advance
"any small object, accidentally dropped, goes and hides behind a larger object."
ALIBE - Artificial LIfe BEing. In search of building autonoumous land robot
  • stamptrolstamptrol Posts: 1,731
    edited 2007-05-02 12:08
    Yep, thats what step-conversion is all about.
    BUT, that does not mean you can draw several amps from the high side with only a watch battery on the input side!
    As a rule of thumb: input volts x input amps = output volts x output amps x .80, your mileage may vary.
    Cheers
    Tom Sisk
    http://www.siskconsult.com
    edited 2007-05-02 13:04
    Try searching the Wikipedia for voltage conversion or "boost converter".
  • SuperwormsSuperworms Posts: 118
    edited 2007-05-03 21:41
    also look at the MintyBoost.A usb battery powered charger
    Equipped with his 5 senses, man explores the world around and calls his adventure science
    -Edwin Hubble
  • Capt. QuirkCapt. Quirk Posts: 872
    Check out this thread 300 Volts in a roll of film
    Also a good 2 part series in a Nuts n Volts artical, "High voltage PIC" in the September & October 2006 issues
