SX-Key not found on COM1
I just got my SX kit LITE the other day and I have had problems programming it from the start. I will try and provide as much info as possible on my situation:
- The error I get is SX-Key not found on COM1
- 90% of the time I get this error, the other 10%, it works fine after fooling with it or it starts to communicate, then cuts off.
- The serial cable is connected to COM1 for sure (I only have one serial port anyways)
- I have tried two cables, both program my Basic Stamp 2 with no problem
- I have tried this on two computers, both program my BS2 fine
- Power is getting to the SX-Key header from the Tech Board
- I am using a Tech Board
- The serial ports on both computers work fine with other serial devices
- No other program is using the serial ports at time of programming/debugging
Anyone have any idea what's wrong? Generally, when it starts working, I have tried to program it many times before and have unplugged the Key and the power multiple times and in different orders.
Thanks in advance,
Dan
Thanks in advance,
Dan
So, when it's powered up and you get the error message, break out the voltmeter and measure +V.
After all, I am using one of the Parallax boards, so the regulator should be suited to this application, but you never know.
I did notice something peculiar though...when the SX-Key works, it gets warm (from what I have read so far, thats normal behavior), but when it won't program/debug and I get that error, it puts out little to no heat. Not sure if that helps at all, but I though I would mention it.
Thanks for your suggestion!
Dan
I have had trouble similar to what you describe (though less severe) on my Windows 2000 computer. My XP Pro computer has no trouble at all. I have no idea whether it is the OS or the computer. Both use motherboard connected serial ports.
- Sparks
-Dan
I didn't spend $130 on this stuff to have it sit on my desk...
-Dan
Chris Savage
Parallax Tech Support
I don't understand why the port would be in use by something else, as the only other thing I use thats serial is my basic stamp, and that software isn't even installed on this computer (it is on my other one that I tried this with).
Any other suggestions?
-Dan
EDIT: I got it to work for a bit. I just unplugged the Key and plugged it back in and it worked. I tested it again though, but unplugging it and plugging it back in, and it stopped working. This thing is very particular.
Also, when I unplug it when it's not working, it's barely warm, but when I unplug it after it has be working, it's noticeably warmer (not hot though).
Again, thanks for the suggestions.
Post Edited (Ductapemaster) : 5/6/2007 10:44:49 PM GMT
Chris Savage
