Two RFID Card Readers To a Gate Opener (Basic Stamp had a mishap with Lighting — Parallax Forums
sam_sam_samsam_sam_sam Posts: 2,286
edited 2008-07-24 21:34 in Robotics
Hi EveryOne
This is a Project that i have been working on for about two months now and its about 80% done now
I have Card Readers up and running and thought that i would post it now
What i have done is that i want to have a Card Reader as you come in to the yard·and one·Card Reader as you leave
The·reason i built this that the· cost of the remotes are $39.00 dollars each· where as the cards are $ 2.25 each·from
Parallax and give them to the people that i was to come in my yard
I want to THANK Chirs for all of his help in this project and All that helped·in this Post
http://forums.parallax.com/showthread.php?p=641588
Here is the code for this Project and some photo of the project
To hook up the Card Readers to the Basic Stamp··I used Cat 5 Cable
To hook up Gate Opener to the Basic Stamp··I used some CMA type T6 Cable
I am using the power supply on the Gate Opener to charge the batterys
I am using PVC piping for all cables that go in the ground
The Card Reader are Powered by one 6 volt 7 amphr battery·for each Card·Reader and the two battery are wired in
(+·· one battery· To - on the other battery ) to make 12 volts
So· Gate Opener·battery ·charger ·can charge both batterys
The Gate Opener can have two batterys in the case
I· hope that some else· that is thinking of doing the same thing this will give you some·· idea.gif
hop.gif.........We are so happy that this up and running............jumpin.gif
··Thanks for any·idea.gif·that you may have and all of your time finding them
Sam
Post Edited (sam_sam_sam) : 7/24/2008 1:09:18 AM GMT
    edited 2007-04-30 16:59
    Hi EveryOne
    I will post more photo as i get more of this Project compled
    The inside of the Basic Stamp Controler Box maybe later Today
    Sam
    edited 2007-05-06 01:30
    Hi EveryOne
    UpDate the Gate Opener is working Great for a week now and working Strong
    UpDate
    ·There was changed made·from IDX VAR Byte to IDX VAR Word because·the byte index was not big enough for ALL·the Tags that·I want to use·
    So the updated·code routine is posted below
    Sam
    Post Edited (sam_sam_sam) : 5/7/2007 2:05:34 PM GMT
  • jeffjohnvoljeffjohnvol Posts: 197
    edited 2007-05-11 17:59
    Sam, Neat project!
    How close does the card need to be to your receiver?
    Jeff
    edited 2007-05-13 21:41
    Jeff
    Thank You for your reply
    The card has to be·ON the cover of the box·· like in the photo to work because the way i had to mount the card reader·but very well and i am going
    to add a Basic Stamp in the house to see·who at the gate and to be able to open the gate at house·I am working on how to write the code to do this
    now so may be awhile before i have all of it work out but·i will let all you know when i have it up and running
    Here is the link to where i am working on how to do this part of the project
    http://forums.parallax.com/showthread.php?p=650139
    Sam
    Post Edited (sam_sam_sam) : 5/31/2007 5:56:41 PM GMT
    edited 2008-07-24 01:22
    ····························· Today was not a good day for the
    ·······························that was at my house today
    ·( It was not a direct hit This has not given one bit of trouble until today)
    I knew something was not right when·I went to get the mail after the storm
    One of the card readers the green led was· ON·so I try the other to see if it was
    working it was not I power down the Basic Stamp and the Card Readers
    Then power all of it back up again and try both card reader but only one was
    working so power back down and changed just the Basic Stamp Chip only
    Then powered everything back up and everything was working again smile.gif·smile.gif·smile.gif
    One thing that·I notice was the Basic Stamp Chip was very warm
    It has to be one of the set of pins that when to the card reader
    Sam
    Post Edited (sam_sam_sam) : 7/24/2008 3:35:14 AM GMT
    edited 2008-07-24 01:29
    It is hard to protect any kind of complex electronic equipment from power line surges, let alone nearby lightning strikes with their huge induced voltages and currents. Lots of things help like shielding, bypassing any kind of signal or power line that leaves the box, optoisolators. None are absolute protection, but all help.
    edited 2008-07-24 01:39
    How would you use a optoisolators on the card reader pins that go to the Basic Stamp
    I used cat5 cable from the Card Reader to the Basic Stamp
    Would you do it like power comming to a· I/O pin on the Basic Stamp
    This is very true
    Sam
    Post Edited (sam_sam_sam) : 7/24/2008 1:45:49 AM GMT
  • JlarsonJlarson Posts: 2
    edited 2008-07-24 07:47
    Lightning damage is by far the hardest to thing to protect electronics from. I do electrical work for water well sites an I have seen first hand what lightning can do. I have seen it blow up breakers and melt lightning rods. Opto-isolators on any digital pins along with MOVs on power supplies and serial pins works but the real problem is the long cable runs. The lightning will induce a charge on any long cable run, sometimes the charge can be more than a MOV or an Opto can take. Shielded cable sould always be used on and outdoor electronic project. I have had good results using Tray Cable. Tray cable is AC/DC 300 volt sunlight resistant and can be used underground without conduit and is avalable in shielded and un-shielded. Look up Northern Arizona Wind And Sun, they have a large selection under the electrical parts section.
    edited 2008-07-24 11:46
    Jlarson
    Thank You for the web link that will help a lot
    http://store.solar-electric.com/12-3-tc.html
    Sam
    Northern is a great place to get parts for any solar project too. I forgot only ground the cable shield on one end otherwise it will create a ground loop.
