Two RFID Card Readers To a Gate Opener (Basic Stamp had a mishap with Lighting
Hi EveryOne
This is a Project that i have been working on for about two months now and its about 80% done now
I have Card Readers up and running and thought that i would post it now
What i have done is that i want to have a Card Reader as you come in to the yard·and one·Card Reader as you leave
The·reason i built this that the· cost of the remotes are $39.00 dollars each· where as the cards are $ 2.25 each·from
Parallax and give them to the people that i was to come in my yard
I want to THANK Chirs for all of his help in this project and All that helped·in this Post
http://forums.parallax.com/showthread.php?p=641588
Here is the code for this Project and some photo of the project
To hook up the Card Readers to the Basic Stamp··I used Cat 5 Cable
To hook up Gate Opener to the Basic Stamp··I used some CMA type T6 Cable
I am using the power supply on the Gate Opener to charge the batterys
I am using PVC piping for all cables that go in the ground
The Card Reader are Powered by one 6 volt 7 amphr battery·for each Card·Reader and the two battery are wired in
(+·· one battery· To - on the other battery ) to make 12 volts
So· Gate Opener·battery ·charger ·can charge both batterys
The Gate Opener can have two batterys in the case
I· hope that some else· that is thinking of doing the same thing this will give you some··
.........We are so happy that this up and running............
··Thanks for any·
·that you may have and all of your time finding them
Sam
Post Edited (sam_sam_sam) : 7/24/2008 1:09:18 AM GMT
··Thanks for any·
·that you may have and all of your time finding them·
Sam
I will post more photo as i get more of this Project compled
The inside of the Basic Stamp Controler Box maybe later Today
··Thanks for any·
Sam
UpDate the Gate Opener is working Great for a week now and working Strong
Thanks Chris for all of your help......................
UpDate
·There was changed made·from IDX VAR Byte to IDX VAR Word because·the byte index was not big enough for ALL·the Tags that·I want to use·
So the updated·code routine is posted below
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 5/7/2007 2:05:34 PM GMT
How close does the card need to be to your receiver?
Jeff
Thank You for your reply
The card has to be·ON the cover of the box·· like in the photo to work because the way i had to mount the card reader·but very well and i am going
to add a Basic Stamp in the house to see·who at the gate and to be able to open the gate at house·I am working on how to write the code to do this
now so may be awhile before i have all of it work out but·i will let all you know when i have it up and running
Here is the link to where i am working on how to do this part of the project
http://forums.parallax.com/showthread.php?p=650139
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 5/31/2007 5:56:41 PM GMT
····························· Today was not a good day for the
Basic Stamp It got Zap by a Lighting Strom·
·······························that was at my house today
·( It was not a direct hit This has not given one bit of trouble until today)
I knew something was not right when·I went to get the mail after the storm
One of the card readers the green led was· ON·so I try the other to see if it was
working it was not I power down the Basic Stamp and the Card Readers
Then power all of it back up again and try both card reader but only one was
working so power back down and changed just the Basic Stamp Chip only
Then powered everything back up and everything was working again
One thing that·I notice was the Basic Stamp Chip was very warm
It has to be one of the set of pins that when to the card reader
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 7/24/2008 3:35:14 AM GMT
Lots of things help like shielding, bypassing any kind of signal or power line that leaves the box, optoisolators. None are absolute protection, but all help.
How would you use a optoisolators on the card reader pins that go to the Basic Stamp
I used cat5 cable from the Card Reader to the Basic Stamp
Would you do it like power comming to a· I/O pin on the Basic Stamp
It is hard to protect any kind of complex electronic equipment from power line surges, let alone nearby lightning strikes with their huge induced voltages and currents.
This is very true
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 7/24/2008 1:45:49 AM GMT
Thank You for the web link that will help a lot
Look up Northern Arizona Wind And Sun
http://store.solar-electric.com/12-3-tc.html
··Thanks for any·
Sam
