PIR distance to BS2
Hello,
· What is required to have the PIR operate with the BS2 from·60' to 80'·?
Amplifier ?
Size and type wire ?
Or is it even practical ?
RC
Post Edited (curious1) : 4/29/2007 7:30:19 PM GMT
Amplifier ?
RC
- Stephen
·· Several PIR's will be connected to the BS2 and the farthest PIR sensor will be 60 t0 80 feet from the BS2.
I know that the range of the PIR sensor is only up to 20' in the BEST of conditions.
Seems like a long way to push 5v.
Yes.... that looks better.
I'll be more careful next time,
Thanks Stephen,
RC
Can someone give me an idea of how far from the BS2 I can expect to use a PIR sensor with this cable without the need of anymore hardware ?
RC
Have you considered using radio transmitters for that distance? You could use an SX chip with a radio transmitter to send a signal to the BS2 when the PIR spots something.
I'm doing something similar to this for Halloween props, but I built a mini wireless network. Each of the props can talk to one and other to update movement status and all. I have several PIRs along with PING sensors which all relay their data to a BS2 that has a receiver.
Dan
Post Edited (DosManDan) : 4/30/2007 4:24:32 AM GMT
I still wonder what the max. distance would be with wire.
Third question: What have you found to be the effective range with the radio tx. ?
Thanks Dan,
RC
I'd love to see an overview of your props system if you're of a mind to share it.
TIA
Bruce Bates
Post Edited (Bruce Bates) : 4/30/2007 9:33:24 AM GMT
Since Parallax sells similar type devices, I don't want to write anything that would take business away from them. They·sell transmitter and receivers which I assume work terrifically, as do their other items. If you would like specific information regarding the parts I used, please e-mail me.
I'd be more than happy to post the code I have along with pictures of the devices. I'll put them under the finished projects part of the Forum and post a link here for you.
I have personally tested the transmitters and receivers out to 60FT with no problem at all. I've also tested them inside the house at distances of 40FT, through walls and all. The only problem I found was not to put it on a glass table with wine bottles around. The signal started to scramble. I'm sure you could improve any of these distances by using an encoder chip or writing a Manchester encoding algorithm.·
Although I used a mix of BS-2 and SX chips, you can use either one exclusively without any problem.
Dan
Post Edited (DosManDan) : 4/30/2007 11:13:35 PM GMT
I'll post a solution using radio transmitters and receivers along with a PIR sensor since this is what the original question was. I'll also post other solutions as soon as I have time. If you have a specific question, feel free to e-mail me and I'll get back to you as soon as I can.
Dan
