electronic view finders as microscreens for prop applications
Graham Stabler
A comment in Bassmaster's thread on pocket TV's about camcorders reminded me that I have the eye piece of electronic viewfinder from an old camcorder, I know it works with a standard video input so it will work with the propeller probably. Unfortunately it is approximately 5hrs drive away from me but rest assured I will be trying it out as soon as I get home.
That aside electronic view finders could make either tiny screens for portable apps or can create large virtual screens. They should not be too expensive just because they are component parts of other items, at least I hope.
This one even does VGA:
www.oriscape.com.cn/EN/e_VF-3.htm
Anyway something to think about. I'm thinking a pair of propcams and a pair of screens and I could create bionic vision goggles!
Graham
Graham
A couple of those, helmet,a gyro chip, accelerometer, some rf transceivers,·a Gatling gun and mobile platform.....you have a new RPV tank. [noparse]:)[/noparse]
James L
http://www.myvu.com/
It's Only A Stupid Question If You Have Not Googled It First!!
Do you just use them with a video iPod, or have you been able to hack them for other uses?
I've seen some of those video glasses for ipods on ebay for pretty good prices and they have video in cables too.
Graham
The camera, transmitter, and display are all likely to be off-the-shelf parts and easily modified. The display is probably 320x200 or thereabouts. Perfect for low-res video...
I've taken it to pieces because I have a few lumiled K2 LEDs with lenses that kick out 160 lumen, I think it might make a short range micro projector, either way it will be great fun to play with.
Graham
That is great....I'll start looking for one now.
James L
Graham
James L
I have a very old (1991) Sony handycam w/ B&W view finder.· I am looking forward to using that view finder in my project.· However, before I ripped it open, I wanted to get input from this grp.·
Please look at the attached pictures.· Can someone tell me which of these wires mean what and where they need to be hooked into on the Prop Demo board.· from the pictures, you can tell that the VF is really vintage [noparse]:)[/noparse]· - almost like a picture tube.
Also, from the pics, you can tell that there are 4 wires (3 grey and 1 while) that go into the camera.· I am hoping I will be able to easily hook this up to my demo board.
thanks in advance guys
"any small object, accidentally dropped, goes and hides behind a larger object."
ALIBE - Artificial LIfe BEing. In search of building autonoumous land robot
Parallax Forums - If you're ready to learn, we're ready to help.
Post Edited (CJ) : 4/27/2007 8:54:00 PM GMT
You will need the PCB, there only seem to be three wires going back to the camcorder, two will be power and the remaining one video, follow CJ's advice to find the GND and 5v and the one left is your video.
If the camcorder still works powering it up will be one way to check those signals.
Graham
She's a B&W beauty. Please see pics.
Graham, thanks·for kicking off this thread!
Your 4th photo is sort of scary. Hopefully you know where the HV on that pcb is.
It could be several hundred volts. Looked very close to the Demo board crystal.
Could possibly lose the Prop and the viewfinder if it ZAPs on something if one isn't
careful. Just an observation. If you have a high voltage range on your multimeter
check the voltage on that heavily insulated wire conductor.
Harley Shanko
h.a.s. designn
good observation [noparse]:)[/noparse]
Its a shame there is nothing a bit more off the shelf available though those ipod video specs might be worth a look at as they take video in.
Graham
