BS2p40 and Cascading TPIC6595N devices
Bill Chennault
All--
How may I calculate the number of TPIC6595N shift registers I can cascade from a single pin of a BS2p40 without exceeding the current draw of the BS2p40's pin?
If this question needs refinement, will you help me do so?
Thanks!
--Bill
You are what you write.
Thanks!
--Bill
as driving essentially gates of DMOS devices. In order to calculate the
transient input current, you would have to know the risetime of the Basic
Stamp output signals as well as the input capacitance of the TPIC6595N
logic inputs.
I couldn't find any input capacitance listed in the TI data sheet. Maybe a
call to a nearby TI Fields Sales office could help pin down this parameter.
In any event, I think you could connect quite a few TPIC6595N logic
inputs to the BS2P40 output pins without damage since you will be driving
essentially only the gate capacitor of a DMOS device.
ristetime of BS2p40 Stamp output voltage = dv/dt = 20 volts/microsecond
input capacitance of TPIC6595N logic input = C = 50 picofarads
Then the peak transient current drawn from the Stamp output pin will be:
I = C*(dv/dt)
I = (20*10^6)* 50*10^(-12) = 1 milliamp
Since each output pin of the BS2P40 can source 30 milliamps, you
could connect 30 TPIC6595N devices to the BS2P40.
These numbers are probably in the ballpark.
It was very gracious of you to go to all that work. Thank you very much!
I have no end-goal in mind other than experimentation. However, my experimentation numbers involve 8 TPIC6595 per pin for a maximum of 8 mA, well within your calculations. Now, I just need to look up the maximum current draw allowed by the entire BS2p40 and multiply by 32.
--Bill
The 1 ma current I calculated is a transient current and it ONLY flows when a
Stamp output pin is rising or falling. No current would be drawn while the
Stamp output pin is a constant hi or low. So you only have to add up the
currents delivered by pins that change state simultaneously. Even then, it
is only a pulsed load current.
To be really on the safe side, put a 220 ohm resistor in series with each Stamp
output pin.
Got'cha!
And thank you again.
--Bill
