BS2p40 and Cascading TPIC6595N devices — Parallax Forums
Bill ChennaultBill Chennault Posts: 1,198
edited 2007-04-26 18:01 in BASIC Stamp
All--
How may I calculate the number of TPIC6595N shift registers I can cascade from a single pin of a BS2p40 without exceeding the current draw of the BS2p40's pin?
If this question needs refinement, will you help me do so?
Thanks!
--Bill
You are what you write.
  • phil kennyphil kenny Posts: 233
    edited 2007-04-26 14:18
    The TI data sheet shows the equivalent input circuit for the logic signals
    as driving essentially gates of DMOS devices. In order to calculate the
    transient input current, you would have to know the risetime of the Basic
    Stamp output signals as well as the input capacitance of the TPIC6595N
    logic inputs.
    I couldn't find any input capacitance listed in the TI data sheet. Maybe a
    call to a nearby TI Fields Sales office could help pin down this parameter.
    In any event, I think you could connect quite a few TPIC6595N logic
    inputs to the BS2P40 output pins without damage since you will be driving
    essentially only the gate capacitor of a DMOS device.
    edited 2007-04-26 14:50
    Making a few assumptions about the signals involved:
    ristetime of BS2p40 Stamp output voltage = dv/dt = 20 volts/microsecond
    input capacitance of TPIC6595N logic input = C = 50 picofarads
    Then the peak transient current drawn from the Stamp output pin will be:
    I = C*(dv/dt)
    I = (20*10^6)* 50*10^(-12) = 1 milliamp
    Since each output pin of the BS2P40 can source 30 milliamps, you
    could connect 30 TPIC6595N devices to the BS2P40.
    These numbers are probably in the ballpark.
  • Bill ChennaultBill Chennault Posts: 1,198
    edited 2007-04-26 15:31
    phil--
    It was very gracious of you to go to all that work. Thank you very much!
    I have no end-goal in mind other than experimentation. However, my experimentation numbers involve 8 TPIC6595 per pin for a maximum of 8 mA, well within your calculations. Now, I just need to look up the maximum current draw allowed by the entire BS2p40 and multiply by 32.
    --Bill
    edited 2007-04-26 16:58
    Only one more comment, Bill.
    The 1 ma current I calculated is a transient current and it ONLY flows when a
    Stamp output pin is rising or falling. No current would be drawn while the
    Stamp output pin is a constant hi or low. So you only have to add up the
    currents delivered by pins that change state simultaneously. Even then, it
    is only a pulsed load current.
    To be really on the safe side, put a 220 ohm resistor in series with each Stamp
    output pin.
    phil--
    Got'cha!
    And thank you again.
    --Bill
