Wheels for my Bot
For the last few months I have been concentrating on the electronics and programming of a robot, now I'm going to start to build one.
what I need is a good source of Wheels I need them to be durable and around 4"-5" in diameter and able to hold around 10-15 lbs.
What is every one out there using?
I purchased the Track system from Lynxmotion and spent a bunch on money only to decide that I want a couple of wheels instead.
Any leads would be greatly appreciated.
Eric
Post Edited (SailerMan) : 4/20/2007 10:45:27 PM GMT
Eric
I've used these (link below) before and was quite happy with them:
http://www.herbach.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=HAR&Product_Code=TM89WHL2677
You may want to edit your message, as it now reads:
"what I need is a good source of Wheels I need them to be durable and around 4"-5" in diameter and able to hold around. "
"able to hold" what?
Bruce Bates
Take a look at 'trainer wheels' for bicycles.
They can handle the weight and are very reasonalble in cost. If you look at industrial casters and barrow wheels, you will pay more.
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
- Stephen
If you want some quality wheels for your robot I would look into the different wheels from Colson. They are great wheels for use on a robot. Some of their larger wheels were used on a ton of the BattleBot robots and one of their medium wheels is used on the HERO 2000 base. I would certainly recommend them for a robot base. You can check out their offering at:
http://www.colsoncaster.com/performa-wheel-choice.html
Hope this helps,
Robert
The main disadvantage is, they are not light weight.
But I think they're more like 7".
Ken
