Wheels for my Bot — Parallax Forums
Wheels for my Bot
SailerManSailerMan Posts: 337
edited 2007-04-23 00:41 in General Discussion
For the last few months I have been concentrating on the electronics and programming of a robot, now I'm going to start to build one.
what I need is a good source of Wheels I need them to be durable and around 4"-5" in diameter and able to hold around 10-15 lbs.
What is every one out there using?
I purchased the Track system from Lynxmotion and spent a bunch on money only to decide that I want a couple of wheels instead.
Any leads would be greatly appreciated.
Eric
Post Edited (SailerMan) : 4/20/2007 10:45:27 PM GMT
  • Bruce BatesBruce Bates Posts: 3,045
    edited 2007-04-20 14:30
    Eric -
    I've used these (link below) before and was quite happy with them:
    http://www.herbach.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=HAR&Product_Code=TM89WHL2677
    You may want to edit your message, as it now reads:
    "what I need is a good source of Wheels I need them to be durable and around 4"-5" in diameter and able to hold around. "
    "able to hold" what?
    Bruce Bates
    edited 2007-04-22 07:04
    Try anyplace that sells bicycles.
    Take a look at 'trainer wheels' for bicycles.
    They can handle the weight and are very reasonalble in cost. If you look at industrial casters and barrow wheels, you will pay more.
    "If you want more fiber, eat the package.· Not enough?· Eat the manual."········
    ···················· Tropical regards,····· G. Herzog [noparse][[/noparse]·黃鶴 ]·in Taiwan
    edited 2007-04-22 16:27
    I have a related question. Most wheels you find for lawnmowers or training wheels have bearings/bushings. How do you go about fixing them so you can use them as drive wheels? Thanks.
    - Stephen
    edited 2007-04-22 16:48
    Hello Eric,
    If you want some quality wheels for your robot I would look into the different wheels from Colson. They are great wheels for use on a robot. Some of their larger wheels were used on a ton of the BattleBot robots and one of their medium wheels is used on the HERO 2000 base. I would certainly recommend them for a robot base. You can check out their offering at:
    http://www.colsoncaster.com/performa-wheel-choice.html
    Hope this helps,
    Robert
  • Capt. QuirkCapt. Quirk Posts: 872
    edited 2007-04-22 17:51
    Try some 6" GoPed tires, they have a good compound and there stock rims·are plastic and there are·all kinds of aftermarket billet rims avaliable (and Spining hub caps).
    The main disadvantage is, they are not light weight.
    edited 2007-04-22 18:59
    Yeah, I'm with Quirk's solution. That's what I've been using.
    But I think they're more like 7".
    Ken
  • SailerManSailerMan Posts: 337
    edited 2007-04-22 23:05
    Thanks all, I appreciate the ideas.
  • jeffjohnvoljeffjohnvol Posts: 197
    edited 2007-04-23 00:22
    Check www.mcmaster.com and put "casters" in the search criteria. They are mostly industrial supplies, but you can find all kinds of specialized equipment and they are priced very well.
    edited 2007-04-23 00:36
    There's a whole nother seperate discussion on this topic, attaching the wheels to your motor shaft or drivetrain. That can be a trick in itself and often dictates the design of wheel chosen for the task.
  • ForrestForrest Posts: 1,341
    FYI the local Home Depot has 6 inch lawn mower tires mounted on a plastic wheel for $4.99 each. They ought to support at least 15 lbs each.
