SSR with BS2
Hello,
I have several of these and would like to use them with my BS2. Is anything else required to use them with an out pin ?
Thanks, RC
120/240 Volt Solid State Relays
Thanks, RC
I'll just use the 220 resistor to be safe.
These are hassle free and pcb models are cheap, $12 a pop.
Thanks Mike,
RC
Another useful feature i have discovered with SSR's is their ability to switch far lesser AC voltages than their rated voltage ie instead of just switching 230V ( I live in the UK) I have had them successfully switching voltages as low as 12VAC.
One more feature is that they can also switch a dimmed mains input useful for setting a preset level of lighting and switching this on and off (used in my work).
A GOOD meter is on my wish list.
I will only have 1 relay per pin, 4 total.
RC
