SSR with BS2 — Parallax Forums
SSR with BS2
curious1curious1 Posts: 104
edited 2007-04-23 09:37 in BASIC Stamp
Hello,
I have several of these and would like to use them with my BS2. Is anything else required to use them with an out pin ?
Thanks, RC
120/240 Volt Solid State Relays
612 x 200 - 7K
780 x 731 - 31K
    edited 2007-04-22 04:05
    If the signal input resistance is indeed 1K, you should be able to drive it directly from a BS2 pin. The main issue is that the input be current limited to something the BS2 can handle (roughly 20ma max.) Perhaps they have a datasheet that's more explicit about this. You can always add an additional 220 ohm resistor in series with the I/O pin to "play it safe" until you can check for sure. The minimum voltage (3V) should work.
  • curious1curious1 Posts: 104
    edited 2007-04-23 01:04
    First post has·all of the info that I could find.
    I'll just use the 220 resistor to be safe.
    These are hassle free and pcb models are cheap, $12 a pop.
    Thanks Mike,
    RC
    edited 2007-04-23 08:45
    In my experience of working with several different types of SSR and measuring the current drawn at the input stage I have found that on the whole they·mostly tend to draw around the 1ma range @12v(havn't tested for 5V)·so i'm assuming several on one pin shouldn't be a problem, have you access to a current meter? Connect a battery or PS to the SSR and measure the current.
    Another useful feature i have discovered with SSR's is their ability to switch far lesser AC voltages than their rated voltage ie instead of just switching 230V ( I live in the UK) I have had them successfully switching voltages as low as 12VAC.
    One more feature is that they can also switch a dimmed mains input useful for setting a preset level of lighting and switching this on and off (used in my work).
    Thanks skylight,
    A GOOD meter is on my wish list.
    I will only have 1 relay per pin, 4 total.
    RC
