Ultimate Protoboard Design?
This might be like trying to trap a unicorn, but I'm shooting for the ultimate protoboard here. [noparse]:)[/noparse]
Before I heat up my soldering pencil... What have I missed?
Oldbitcollector
"Two things are infinite: the universe and human stupidity; and I'm not sure about the universe." -Albert Einstein
Oldbitcollector
I would be prefer a solution without switches. Uwe Schmidt has built a very nice development board which is full compatible to the demo board from Parallax.
http://www.tdus.eu/online/tduscms/index.php?id=5
Onboard you have only the LED's and a serial connection. You can disconnect the LED's by a jumper. Then you can extend the board with your desired configuration by little modules which you can attach to the board. So you will be able to customize your board to any configuration which is using a Propeller.
If you are showing the shop site from Uwe please click on the left menu at "Parallax Propeller" and then at "Propeller Board" to see all currently available modules.
Rich
Oldbitcollector
Rich
Oldbitcollector
Rich
_____________________________________
Albert Einstein was wrong about everything... except stupidity.
Personal experience must count for something[noparse]:)[/noparse]
I only look like I have a plan!
The comments and code above are proof that a million monkeys with a million propeller chips *could* write Shakespeare!
Rich
Put Einstein in a room with the Bros. Gracey and all the girls would be begging for more props[noparse]:)[/noparse]
