Propeller Cap in EETIMES — Parallax Forums
CHIPKENCHIPKEN Posts: 45
edited 2007-04-11 15:47 in Propeller 1
jumpin.gif·The March 26 issue of EETIMES magazine on page 48 shows the Propeller Cap·that all the engineers should wear when showing off their true multiprocessing chip programs.
Chuck
    edited 2007-03-27 21:12
    Here is the ad in EETIMES:
    Chip Gracey
    183 x 800 - 45K
  • Paul Sr.Paul Sr. Posts: 435
    edited 2007-03-28 16:43
    GREAT Ad!!
  • LitefireLitefire Posts: 108
    edited 2007-03-28 21:32
    brilliant. now, where can i order one of those hats?
    ~~Brian
  • rjo_rjo_ Posts: 1,825
    edited 2007-03-28 23:08
    I'm holding out for a 3D visor.
    517 x 551 - 22K
    edited 2007-04-10 22:02
    Good ad!
    P.S. any idea yet when the latest prop version is being released?(I know, you are tired of hearing that question but I am saving my money!)
    Fix it if ain't broke·
    D Rat
    edited 2007-04-10 22:47
    If all goes well, about 6 months to a year for the 64 pin version of the current architecture, and 18 months to 2 years for the next architecture.
    Paul Baker
  • HarleyHarley Posts: 997
    edited 2007-04-10 23:30
    WHAT??
    Paul Baker said...
    I'm confused. I thought the 160 MHz Prop with 8/16 cogs WAS the next one to come out.
    Does the 64-pin version of the current architecture 'only' run at 80 MHz and support the B-Port 32 I/Os? And when you say '64 pin' I assume you mean 64 I/O ports. Which might translate into a 84-pin SMD package.
    So 18 mo to 2 yr for the 160 MHz, 64 I/O guy? Sure hope that one has 16 cogs; should with twice the I/Os!
    Wish Parallax had a NAME for the various Propellers so we can understand which one is actually being referenced. Any one else feel a bit confused with Paul's comment?
    Harley Shanko
    h.a.s. designn
    Post Edited (Harley) : 4/10/2007 11:38:52 PM GMT
    edited 2007-04-10 23:38
    You have it correct, current architecture 64 pin means the existing chip with Port-B implemented. There is no need to name chips until we are actually at a point where marketing gets involved, obviously the current chip is the P8X32A, the 64 pin version of the current architecture will likely be called the P8X32B.
    Paul Baker
    Post Edited (Paul Baker (Parallax)) : 4/10/2007 11:43:23 PM GMT
    edited 2007-04-10 23:47
    Sorry for the confusion. It's true that we are several months away from having the P8X32B - a 64 I/O version of the current Propeller. The next generation Propeller does not have a name yet. It is at least a year away.
    Here is the planned pinout for the P8X32B:
    Chip Gracey
    Post Edited (Chip Gracey (Parallax)) : 4/11/2007 4:10:19 AM GMT
    931 x 898 - 125K
    edited 2007-04-10 23:51
    Thanks Paul, for straightening out this matter.
    I'm interested in both the 160 MHz speed AND more than 32 I/Os.
    But 8 cogs in that neat 'beast' may not be enough for a particular project in mind.
    Yeah! for 16 cogs.
    Harley Shanko
    h.a.s. designn
    edited 2007-04-11 01:26
    Thanks for the·timing info on the apprx release dates on both. I will be looking forward to both chips.
    Thanks again, DAVE
    D Rat
  • mirrormirror Posts: 322
    edited 2007-04-11 01:41
    I'd love this little beastie. In my current project I'm good for cogs, but am really struggling on what to leave out with only (32 - 4) I/O pins. Even those 4 pins are put to good use, as I have an MAX232 and DB9 on the comms pins and a real time clock with the program memory on P28-29.
    Is the release for the chip planned to be in both surface mount packaging variations? For the P8X32A you have Q44 and M44 variants - so will there be a Q80 and M80. The drawing looks to be the M80.
  • bambinobambino Posts: 789
    Yes,
