75MHz crystal for SX28. How to connect ?
I am looking for information on running a SX28 at 75 MIPS. What crystal would I use and dose it need capacitors like the PIC Chips or can they be connected to ground like the 50 MHz resonator parallax?
Post Edited By Moderator (Bean (Hitt Consulting)) : 4/8/2007 12:49:10 PM GMT
At this frequency, the SX dissipates a lot of heat. So you will want to consider heatsinking it too — especially if it's installed in an unvented enclosure.
Post Edited (Phil Pilgrim (PhiPi)) : 4/8/2007 5:10:43 PM GMT
Good luck with your project!
DEVICE SX28, OSCHS2, TURBO, STACKX, OPTIONX
would this work for a 75 MHz SX0001 ?
