75MHz crystal for SX28. How to connect ? — Parallax Forums
warnerwarner Posts: 17
edited 2007-05-06 23:24 in General Discussion
I am looking for information on running a SX28 at 75 MIPS. What crystal would I use and dose it need capacitors like the PIC Chips or can they be connected to ground like the 50 MHz resonator parallax?
Post Edited By Moderator (Bean (Hitt Consulting)) : 4/8/2007 12:49:10 PM GMT
  • ForrestForrest Posts: 1,341
    edited 2007-04-08 10:28
    Here's some info from tje SX28 page - see the link at the bottom www.parallax.com/detail.asp?product_id=SX28AC/DP-G
    edited 2007-04-08 17:06
    In my experience, an external oscillator is necessary for operation at 75MHz. A crystal or resonator won't do the job. Parallax offers such an oscillator; or, if space is an issue, you can get a surface-mount oscillator from DigiKey.
    At this frequency, the SX dissipates a lot of heat. So you will want to consider heatsinking it too — especially if it's installed in an unvented enclosure.
    Post Edited (Phil Pilgrim (PhiPi)) : 4/8/2007 5:10:43 PM GMT
  • Capt. QuirkCapt. Quirk Posts: 872
    edited 2007-04-08 22:26
    Just curious, have you tried SX-Sim yet?
    edited 2007-04-09 05:19
    Yes, do read the Parallax appnote. The skull and crossbones is a little over the top, though, so don't be intimidated by it. With care, the SX can safely run at 75MHz. I have a customer whose 75MHz SX system has run continuously for several years without a problem.
    Good luck with your project!
  • warnerwarner Posts: 17
    Would the Code remain the same for a SX0001 ? For a 50 meg ceramic oscillator I am using
    DEVICE SX28, OSCHS2, TURBO, STACKX, OPTIONX
    would this work for a 75 MHz SX0001 ?
