RFID Gun
sanbogsilent
I'm trying to attach an RFID system to a airsoft gun for a school project. The idea is that to fire the gun you must be have the RFID tag (we are putting it in a ring or something of that nature) on you before you can fire the gun. We are using a Parallax RFID reader and a PIC16f877a micro controller.
I was wondering if you guys could give me some feed back on my code. (It's in Assembly, which i'm not as proficient with as i need to be.) Or atleast tell me if it makes sense.
The idea for the code is, it's scans the tag compares it's value to the accepted tag value already programed in the controller and if it matches outputs a high on one of the pins.
any and all suggestions are greatly appreciated.
;****************** ;****List Files**** ;****************** list p=16f877a, r=hex ;********************* ;****Include Files**** ;********************* #include <p16f877a.inc> ;******************** ;****Config Files**** ;******************** ;Standard Config, Using RC circuit as timer __CONFIG _CP_OFF & _WDT_OFF & _BODEN_ON & _PWRTE_OFF & _RC_OSC & _LVP_ON & _CPD_OFF ;******************** ;*****Constants****** ;******************** ;***************** ;****Variables**** ;***************** IDMEMORY equ 50h ;Memory block for input ID tags, 50h-5Ch cblock IDMEMORY tag0i tag1i tag2i tag3i tag4i tag5i tag6i tag7i tag8i tag9i tag10i tag11i endc ALLOWID equ 20h ;Memory block for 'allowed users' cblock ALLOWID tag0 ;0x0A tag1 ;0x00 tag2 ;0x04 tag3 ;0x01 tag4 ;0x05 tag5 ;0x0A tag6 ;0x0B tag7 ;0x06 tag8 ;0x06 tag9 ;0x07 tag10 ;0x0f tag11 ;0x0D endc org 0 goto start org5 ;****************** ;****Main Files**** ;****************** start bsf SSPCON, 5 ;Enable serial communication bsf SSPCON, B'0100' ;SPI to slave mode, clock is SCK pin, SSbar pin control EN bsf STATUS, 5 ;Move to Memory Bank 1 movlw B'00010000' ;Move the number that controls PIN C 4 to W movwf TRISC ;Turn on PIN C4 for input clrw movlw B'00000000' movwf TRISD ;PORT D is all output clrw bcf STATUS, 5 ;Go Back to Memory Bank 0 goto LOOP_STORE_DATA LOOP_STORE_DATA ;This loop will write the 'allowed' ID to memory starting at 20h movlw 0x0A movwf ALLOWID clrw movlw 0x00 movwf ALLOWID+1 clrw movlw 0x04 movwf ALLOWID+2 clrw movlw 0x01 movwf ALLOWID+3 clrw movlw 0x05 movwf ALLOWID+4 clrw movlw 0x0A movwf ALLOWID+5 clrw movlw 0x0B movwf ALLOWID+6 clrw movlw 0x06 movwf ALLOWID+7 clrw movlw 0x06 movwf ALLOWID+8 clrw movlw 0x07 movwf ALLOWID+9 clrw movlw 0x0F movwf ALLOWID+0x0A clrw movlw 0x0D movwf ALLOWID+0x0B clrw goto LOOP_MOVE_DATA LOOP_MOVE_DATA ;This loop repeats 12 times to capture all 12 bytes of ID number movf SSPBUF, W ;Move Serial Buffer to W movwf IDMEMORY movf SSPBUF, W ;Move Serial Buffer to W movwf IDMEMORY+1 movf SSPBUF, W ;Move Serial Buffer to W movwf IDMEMORY+2 movf SSPBUF, W ;Move Serial Buffer to W movwf IDMEMORY+3 movf SSPBUF, W ;Move Serial Buffer to W movwf IDMEMORY+4 movf SSPBUF, W ;Move Serial Buffer to W movwf IDMEMORY+5 movf SSPBUF, W ;Move Serial Buffer to W movwf IDMEMORY+6 movf SSPBUF, W ;Move Serial Buffer to W movwf IDMEMORY+7 movf SSPBUF, W ;Move Serial Buffer to W movwf IDMEMORY+8 movf SSPBUF, W ;Move Serial Buffer to W movwf IDMEMORY+9 movf SSPBUF, W ;Move Serial Buffer to W movwf IDMEMORY+0xA movf SSPBUF, W ;Move Serial Buffer to W movwf IDMEMORY+0xB clrw goto LOOP_COMPARE LOOP_COMPARE ;The comparison loop subtracts the stored input IDMEMORY ;segments from the previously hardcoded ALLOWMEMORY clrw clrf 40h ;40h is used for the 'scratch' work movf ALLOWID, W ;Recall first known byte subwf IDMEMORY, W ;Subtract first known bit from input bit movwf 40h btfsc 40h, 0 ;If the value of 40h is zer, that bit passes the test goto LOOP_MOVE_DATA ;and will skip this step ;If subtraction not = 0, then will restart the checking process clrw clrf 40h movf ALLOWID+1, W subwf IDMEMORY+1, W movwf 40h btfss 40h, 0 goto LOOP_MOVE_DATA clrw clrf 40h movf ALLOWID+2, W subwf IDMEMORY+2, W movwf 40h btfss 40h, 0 goto LOOP_MOVE_DATA clrw clrf 40h movf ALLOWID+3, W subwf IDMEMORY+3, W movwf 40h btfss 40h, 0 goto LOOP_MOVE_DATA clrw clrf 40h movf ALLOWID+4, W subwf IDMEMORY+4, W movwf 40h btfss 40h, 0 goto LOOP_MOVE_DATA clrw clrf 40h movf ALLOWID+5, W subwf IDMEMORY+5, W movwf 40h btfss 40h, 0 goto LOOP_MOVE_DATA clrw clrf 40h movf ALLOWID+6, W subwf IDMEMORY+6, W movwf 40h btfss 40h, 0 goto LOOP_MOVE_DATA clrw clrf 40h movf ALLOWID+7, W subwf IDMEMORY+7, W movwf 40h btfss 40h, 0 goto LOOP_MOVE_DATA clrw clrf 40h movf ALLOWID+8, W subwf IDMEMORY+8, W movwf 40h btfss 40h, 0 goto LOOP_MOVE_DATA clrw clrf 40h movf ALLOWID+9, W subwf IDMEMORY+9, W movwf 40h btfss 40h, 0 goto LOOP_MOVE_DATA clrw clrf 40h movf ALLOWID+0x0A, W subwf IDMEMORY+0x0A, W movwf 40h btfss 40h, 0 goto LOOP_MOVE_DATA clrw clrf 40h movf ALLOWID+0x0B, W subwf IDMEMORY+0x0B, W movwf 40h btfss 40h, 0 goto LOOP_MOVE_DATA goto LOOP_ACTIVATE LOOP_ACTIVATE ;This will activate the firing mechanism movlw B'11111111' movwf PORTD ;ouput a high to PORTD, all pins nop nop nop nop goto LOOP_MOVE_DATA ;check the tag again end
Problem #2 is that you seem to be using the hardware spi port and not the hardware uart. The parallax RFID reader uses asynchronous serial @ 2400 bps. This means that you have to set the SPBRG to a precalculated baud rate (look at the datasheet for a formula). Then use the TXREG & RXREG to get your serial data. Note that you must wait for each byte to come in, not just expect that all of them will be ready when you read from the register.
You may want to look at using a higher level language than assembly. There are plenty of 'free' compilers out there (limited by size of code, etc). I would recommend that you try to look at Parallax micros (the BS2, Propeller, or SX) since they all come with a free high level language compiler that is easy to use.
Harrison
Do you have any suggestions on where to find a free compiler on-line?
Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the Universe trying to produce bigger and better idiots. So far, the Universe is winning.
Microsoft: "You've got questions. We've got dancing paper clips."
