RFID Gun
I'm trying to attach an RFID system to a airsoft gun for a school project. The idea is that to fire the gun you must be have the RFID tag (we are putting it in a ring or something of that nature) on you before you can fire the gun. We are using a Parallax RFID reader and a PIC16f877a micro controller.
I was wondering if you guys could give me some feed back on my code. (It's in Assembly, which i'm not as proficient with as i need to be.) Or atleast tell me if it makes sense.
The idea for the code is, it's scans the tag compares it's value to the accepted tag value already programed in the controller and if it matches outputs a high on one of the pins.
any and all suggestions are greatly appreciated.
;****List Files****
list p=16f877a, r=hex
;****Include Files****
#include <p16f877a.inc>
;****Config Files****
;Standard Config, Using RC circuit as timer
__CONFIG _CP_OFF & _WDT_OFF & _BODEN_ON & _PWRTE_OFF & _RC_OSC & _LVP_ON & _CPD_OFF
;*****Constants******
;****Variables****
IDMEMORY equ 50h ;Memory block for input ID tags, 50h-5Ch
cblock IDMEMORY
tag0i
tag1i
tag2i
tag3i
tag4i
tag5i
tag6i
tag7i
tag8i
tag9i
tag10i
tag11i
endc
ALLOWID equ 20h ;Memory block for 'allowed users'
cblock ALLOWID
tag0 ;0x0A
tag1 ;0x00
tag2 ;0x04
tag3 ;0x01
tag4 ;0x05
tag5 ;0x0A
tag6 ;0x0B
tag7 ;0x06
tag8 ;0x06
tag9 ;0x07
tag10 ;0x0f
tag11 ;0x0D
endc
org 0
goto start
org5
;****Main Files****
start bsf SSPCON, 5 ;Enable serial communication
bsf SSPCON, B'0100' ;SPI to slave mode, clock is SCK pin, SSbar pin control EN
bsf STATUS, 5 ;Move to Memory Bank 1
movlw B'00010000' ;Move the number that controls PIN C 4 to W
movwf TRISC ;Turn on PIN C4 for input
clrw
movlw B'00000000'
movwf TRISD ;PORT D is all output
clrw
bcf STATUS, 5 ;Go Back to Memory Bank 0
goto LOOP_STORE_DATA
LOOP_STORE_DATA ;This loop will write the 'allowed' ID to memory starting at 20h
movlw 0x0A
movwf ALLOWID
clrw
movlw 0x00
movwf ALLOWID+1
clrw
movlw 0x04
movwf ALLOWID+2
clrw
movlw 0x01
movwf ALLOWID+3
clrw
movlw 0x05
movwf ALLOWID+4
clrw
movlw 0x0A
movwf ALLOWID+5
clrw
movlw 0x0B
movwf ALLOWID+6
clrw
movlw 0x06
movwf ALLOWID+7
clrw
movlw 0x06
movwf ALLOWID+8
clrw
movlw 0x07
movwf ALLOWID+9
clrw
movlw 0x0F
movwf ALLOWID+0x0A
clrw
movlw 0x0D
movwf ALLOWID+0x0B
clrw
goto LOOP_MOVE_DATA
LOOP_MOVE_DATA ;This loop repeats 12 times to capture all 12 bytes of ID number
movf SSPBUF, W ;Move Serial Buffer to W
movwf IDMEMORY
movwf IDMEMORY+1
movwf IDMEMORY+2
movwf IDMEMORY+3
movwf IDMEMORY+4
movwf IDMEMORY+5
movwf IDMEMORY+6
movwf IDMEMORY+7
movwf IDMEMORY+8
movwf IDMEMORY+9
movwf IDMEMORY+0xA
movwf IDMEMORY+0xB
clrw
goto LOOP_COMPARE
LOOP_COMPARE ;The comparison loop subtracts the stored input IDMEMORY
;segments from the previously hardcoded ALLOWMEMORY
clrw
clrf 40h ;40h is used for the 'scratch' work
movf ALLOWID, W ;Recall first known byte
subwf IDMEMORY, W ;Subtract first known bit from input bit
movwf 40h
btfsc 40h, 0 ;If the value of 40h is zer, that bit passes the test
goto LOOP_MOVE_DATA ;and will skip this step
;If subtraction not = 0, then will restart the checking process
clrw
clrf 40h
movf ALLOWID+1, W
subwf IDMEMORY+1, W
movwf 40h
btfss 40h, 0
goto LOOP_MOVE_DATA
clrw
clrf 40h
movf ALLOWID+2, W
subwf IDMEMORY+2, W
movwf 40h
btfss 40h, 0
goto LOOP_MOVE_DATA
clrw
clrf 40h
movf ALLOWID+3, W
subwf IDMEMORY+3, W
movwf 40h
btfss 40h, 0
goto LOOP_MOVE_DATA
clrw
clrf 40h
movf ALLOWID+4, W
subwf IDMEMORY+4, W
movwf 40h
btfss 40h, 0
goto LOOP_MOVE_DATA
clrw
clrf 40h
movf ALLOWID+5, W
subwf IDMEMORY+5, W
movwf 40h
btfss 40h, 0
goto LOOP_MOVE_DATA
clrw
clrf 40h
movf ALLOWID+6, W
subwf IDMEMORY+6, W
movwf 40h
btfss 40h, 0
goto LOOP_MOVE_DATA
clrw
clrf 40h
movf ALLOWID+7, W
subwf IDMEMORY+7, W
movwf 40h
btfss 40h, 0
goto LOOP_MOVE_DATA
clrw
clrf 40h
movf ALLOWID+8, W
subwf IDMEMORY+8, W
movwf 40h
btfss 40h, 0
goto LOOP_MOVE_DATA
clrw
clrf 40h
movf ALLOWID+9, W
subwf IDMEMORY+9, W
movwf 40h
btfss 40h, 0
goto LOOP_MOVE_DATA
clrw
clrf 40h
movf ALLOWID+0x0A, W
subwf IDMEMORY+0x0A, W
movwf 40h
btfss 40h, 0
goto LOOP_MOVE_DATA
clrw
clrf 40h
movf ALLOWID+0x0B, W
subwf IDMEMORY+0x0B, W
movwf 40h
btfss 40h, 0
goto LOOP_MOVE_DATA
goto LOOP_ACTIVATE
LOOP_ACTIVATE ;This will activate the firing mechanism
movlw B'11111111'
movwf PORTD ;ouput a high to PORTD, all pins
nop
nop
nop
nop
goto LOOP_MOVE_DATA ;check the tag again
end
Problem #2 is that you seem to be using the hardware spi port and not the hardware uart. The parallax RFID reader uses asynchronous serial @ 2400 bps. This means that you have to set the SPBRG to a precalculated baud rate (look at the datasheet for a formula). Then use the TXREG & RXREG to get your serial data. Note that you must wait for each byte to come in, not just expect that all of them will be ready when you read from the register.
You may want to look at using a higher level language than assembly. There are plenty of 'free' compilers out there (limited by size of code, etc). I would recommend that you try to look at Parallax micros (the BS2, Propeller, or SX) since they all come with a free high level language compiler that is easy to use.
Harrison
Do you have any suggestions on where to find a free compiler on-line?
Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the Universe trying to produce bigger and better idiots. So far, the Universe is winning.
Microsoft: "You've got questions. We've got dancing paper clips."
