Atmel128 based Humanoid
Im gonna build a biped using the propeller. I will use Hitec servos. More info to come.
Intellibrain 2 w/ atmega= 265 dollars
Propeller Proto board= 24.95 dollars
Building a robot using the Propeller= Priceless (Well, almost)
Post Edited (Atmega128_is_better_than_stamp) : 4/1/2007 10:28:02 PM GMT
Im trying to build mine for under 1000 dollars.
Post Edited By Moderator (Chris Savage (Parallax)) : 3/31/2007 2:15:49 AM GMT
I think we can build a better humanoid with Parallax products.
Tom
After all a good number of us use the basic stamp.
T
Good luck in your search.
Post Edited By Moderator (Chris Savage (Parallax)) : 3/31/2007 2:16:25 AM GMT
List of materials so far:
-23 Futuba S3104 servos
-1 Parallax serial servo controller
-1 Atmel Atmega128 on Intellibrain board (or propeller for cost issues)
-1 Video camera for color tracking, motion detection, etc. (What kind should i use. CMU3 is my first idea but maybe a cheap wireless micro cam might work)
Im low on extra cash so if someone can donate soemthing for this project that would be great. I dont know whether I should use the propeller or Intellibrain for the mainboard. Any suggestions are welcome.
Post Edited By Moderator (Chris Savage (Parallax)) : 3/31/2007 2:16:32 AM GMT
With Intellibrain: 988.67 plus 109.00 for CMU=$1097.67
With Propeller=$862.62
Intellibrain is faster.
Propeller is cheaper.
WHAT SHOULD I DO!!!!
Post Edited By Moderator (Chris Savage (Parallax)) : 3/31/2007 2:16:38 AM GMT
Post Edited By Moderator (Chris Savage (Parallax)) : 3/31/2007 2:16:44 AM GMT
- Stephen
Post Edited By Moderator (Chris Savage (Parallax)) : 3/31/2007 2:16:51 AM GMT
Post Edited By Moderator (Chris Savage (Parallax)) : 3/31/2007 2:15:32 AM GMT
Tom
Post Edited (Atmega128_is_better_than_stamp) : 4/1/2007 10:27:25 PM GMT
Oldbit
So, the USD 1000 goal seems to be lost before you even start thinking processors and servos.
BTW. Why do you say the Intellibrain is faster than the Prop? Is it really? I mean 160 MIPS (32 bit) is hard to beat.
Edit: The Atmega128 is an eightbitter with a 16 MHz clock. A nice chip as nice chips go. But having power like a few percent of the Prop.·A couple of 8 bit and·16 bit counters - the Prop has sixteen 32 bit counters. Instead of one 8 bit 16 MHz processor in the Atmega128 the Propeller has eight 32 bit processors ckocked at 80 MHz. The two chips are·in two different·worlds. I recommend a reality check - and, of course, the Propeller. Even pricing is better - catalogue price for the Prop is around half the catalogue price for the Atmega128 processor.
Power compares·like (16x8)/(160x32) or 1/40 or 2.5 %. So, you pay twice as much for 2.5 % of the performance.· And that's not the end of the story. If you ever wanted to do what the Prop can do, performance-wise, you just cannot do it. A multiprocessor system based on the Atmega128 would not be effective - the administration of communication between processors would choke the whole system already somewhere between five or ten processors. The point of diminishing return is probably even lower. To top it off, counter resolution like 12.5 ns, video generator built-in, phoneme generator, flexible communication are all a possibility with the Prop. You need external peripheral circuits for that if you take the Atmega128 road.
I have considered Atmega128 for a couple of projects, but could not use it. Not enough power. Now, when I have tested the Prop features and power, I can not only do what I need to do. I can also replace the 4x20 character alphanumeric display with a 2.5" colour LCD with full graphics. I can measure with a much better temporal resolution and I am even thinking of adding voice output, which will be very valuable when measuring on fast rotating shafts in heavy machinery. Much better safety.
Post Edited (Skogsgurra) : 4/1/2007 10:45:07 AM GMT
Quattro
'Necessity is the mother of invention'
Propeller: Faster, Cheaper
YAY. PROPELLER IT IS!!!!!
For now, it will be locked while it is under review by our forum moderators.
Does anyone know how to modify a Futaba S3305 to go 180 degrees total instead of 90 total?
Chris Savage
Parallax Tech Support
