Propeller data sheet here!!!
cgracey
Thanks to mainly Paul and Stephanie here, we have a preliminary data sheet ready. This has some important graphs of power consumption that have not been released before, plus some electrical specs. We've just·specified a·commercial temperature rating for now, until we do some more tests.
Chip Gracey
Chip Gracey
Regards.
Alberto.
One suggestion, it would be really useful if you could start adding bookmarks to your PDFs as a table of contents in a similar way to how the PIC datasheets do it. The datasheet and propeller manual would be significantly more accessible with them.
I have lost count of how many times I've sworn looking for info in the prop manual due to having to repeatedly return to the contents (which doesnt have hyperlinks) and then repeatedly use goto page til I find what I'm looking for. Conversely, with the PIC datasheets, I can always jump to within a couple of pages of the information I need using just the bookmarks pane in Acrobat Reader.
The propeller manual is huge and I really don't expect you to waste tons of time adding bookmarks to it, but the datasheet is much smaller and it would be great if you could add them there.
Anyway, nice work Paul and Stephanie, the datasheet is going to be extremely useful.
T.
I'll look into doing this... seems to me the last time I tried, Adobe crashed and I had to move on to something else, but since then I have a new version.· I will post update notifications here.
--Jeff Martin
· Sr. Software Engineer
· Parallax, Inc.
Parallax Forums - If you're ready to learn, we're ready to help.
Yes, you're right, 0.3 Vdd.
Yes, or more clearly stated, 2 KB.
Thanks for your input!
--Jeff Martin
· Parallax, Inc.
Post Edited (Jeff Martin (Parallax)) : 3/31/2007 11:03:48 PM GMT
Under maximum ratings, it states 0 to 70 degrees C for ambient temperature under bias, but then in the AC and DC characteristics it states a temperature range of -40 to +125, and it is unclear how that applies to the Min and Max values. There is a clear contradiction there that should be worded in a different manner. It states that the typical values apply at 25 degrees C. IMHO, the maximum rating should simply state TBD, to be determined, and the AC and DC characteristics should reflect testing that has actually been done for variation over temperature and state "preliminary".
Tracy Allen
www.emesystems.com
Our intent is to test the chip at automotive, and rather than resimulating the datapoints when we move to the full datasheet (which would shift all the numbers and likely cause a lot more confusion than this discrepancy), we decided to provide the final number for the sake of consistancy wherever possible.
Paul Baker
Version 0.2 corrects the items noted above, and is attached.· This and future versions will be availabe from the Propelller downloads page.
http://www.parallax.com/propeller/downloads.asp
You can email me directly with any errata you find: editor@parallax.com
-Stephanie Lindsay
Editor, Parallax Inc.
Paul, I don't want to argue about the temperature specs, but I am of those people who jump to the electrical specs. I found your exlanation uhhhh, slippery, and you need to be prepared for the question. Usually there are typical values, min and max, given for operation at room temp., and separate values given for variation over temperature extremes based on statistcal techniques that take into account both real measurements and the design parameters. The statement in that part of the data sheet strongly imples that at least cursory test has actually been done under bias at those temperatures, and that contradicts the statement of maximum values.
There is language that can hedge the bet, which applies admirably to the Propeller: "The xxxxx are designed, characterized and expected to meet these extended temperature limits, but are not (yet) tested at -40°C and 85°C. Guaranteed I grade parts are available. Consult the factory." (that language, except the "yet" are lifted from a Linear Tech data sheet.) To the engineer, that is reassuring without overstating the case, especially in a "preliminary" data sheet.
Tracy Allen
www.emesystems.com
Tracy Allen
www.emesystems.com
One small comment, the logic level thresholds as stated at page 3 (paragraph 1.9 pin Descriptions, P0-P31) seem to be contradictory to those stated at page 20 (Paragraph 7.2, DC characteristics, Vih and Vil). Also page 3 mentions the term "VDC" which is not used in the electrical characteristics, or maximum ratings.
Mahjongg.
Phil
Paul Baker
When you mention memory sizes they are referred to as KB, which most people assume means KBytes. It is customary for CPU specs to reference memory sizes in bytes even if there natural word width is 64 bits. For instance in section 3.3 while the memory is also described as 512 longs, it really should be 2KB or 16Kb, with 2KB being the most common.
Memory sizes in bits are normally reserved for describing memory devices or embedded memory of FPGAs.
Steve
Evanh is of course correct in his interpretation of the term "word". A "word" is the basic addressable unit of a memory absolutely independend of its size, as well as the basic unit to be handled by the ALU.
Early mainframes - generally used as "number chrunchers" - used 30 to 60 bits, as it makes no sense to have less precision for numerical computations.
In certain applications even higher accuracy was needed, and the concept of "DOUBLE" entered early programming languages like FORTRAN IV. These operations were performed with software support on (single) word ALUs.
The next generation of "mini computers" used 16 bits as their "natural" units, mainly driven by cost considerations. Note also that the size of the addressable units was generally coupled with memory width.
In the meantime it had become popular to address memory as "bytes" as non-numerical applications had outplayed the number crunching. As always marketing considerations played their role, as you can announce much larger numbers in bytes than in words
With the advent of double precision ALUs (64 and 80 bits) and ultra-wide memory there is no natural system any longer.
I personally still understand the term "word" in its original context. So I generally speak of words in a COG sometimes creating confusion....
Post Edited (deSilva) : 8/11/2007 9:11:35 AM GMT
