onewire
there is a simple way to connect
a onewire master device to propeller ?
(it seems the 1wire object acts as a master too)
http://ww1.parallax.com/Default.aspx?tabid=65
Howto can i read negative temperature with DS18B20?
The same way as reading positive temperature. The data returned indicates if positive or negative. Have a read of the DS18B20 datasheet.
