Stamp Works Experiment Kit
I was wondering how is the development board mounted for the experiments?· In other words what keeps it from shorting out?· Does it just lay on a piece of anti-static foam?· I don't see any hole for stand-offs or rubber feet.
What I said was "Peel and stick rubber bumpers (feet)" - but then I decided I better check that since I haven't looked at the bottom of the board in many moons! I believe that's what I put on there, though.
Your PDB should have come with 8 rubber feet which stick onto the bottom of the board. These keep the PCB from touching the surface you’re working on. Take care.
Chris Savage
Parallax Tech Support
PAR
