Super Carrier Board Questions.
I have a couple of questions on the Super Carrier board (27130).
Is the 5v coming off of the Voltage Regulator rated at 1 amp (like the BOE board)? I would like to run the Serial LCD (27977) off of the vdd bus, if possible.
Can I solder components onto the board (bottom side)? I would like to do the prototyping with wire wrapping and then finalize the project with solder.
The Super carrier looks like the BOE without the breadboard, is that accurate?
Mitch
Mitch
The holes are plated through as I recall. I've built some projects using this board ... no wire wrap ... all point to point soldering ... worked fine.
Chris Savage
Parallax Tech Support
