battery help — Parallax Forums
battery help
8Ball8Ball Posts: 2
edited 2007-03-22 02:03 in Robotics
I have a battery pack that I want to use for my projects but·I don't have a charger for it does anyone have a schematic for one
    edited 2007-03-22 00:21
    I have a universal charger made by Maha - MH-C777Plus-II. You should be able to find this with a websearch. It requires an external "wall-wart" up to 24V depending on the highest voltage battery you want to charge. Yours looks like a 12V NiCd or NiMH battery pack and you'll need probably 18V for the charger. The charger's documentation discusses the minimum voltage needed.
  • slamerslamer Posts: 52
    I use a Astroflight 112D for all of my Nicad or NiMh battery packs.. It might be a bit over kill for your needs. But it is a really nice charger/discharger and it runs on 12VDC.·It fixes dead batteries and removes the memory effect.
    Heres a few chargers that are available...
    http://www.robotcombat.com/marketplace_chargers.html
    undefinedundefinedundefinedundefinedSteven Kirk Nelson (slamer)
    Team K.I.S.S
    Build Safe, Build Mean, Build Strong!
