ink pc to Parallax Servo Controller (Serial)
Hello,
·I have a new Parallax Servo Controller (Serial). Is it possible to connect the pc serial port 232(rx and tx) to a pin serial I/O of my Parallax Servo Controller? With a max232 ? Have you a shematic or document how explains to do that ?·
Thank for advance. Stéphane Schittek.
Chris Savage
Parallax Tech Support
Stephan S.
Chris Savage
St
·· The problem I see with your schematic is that when the Servo Controller is sending data back it is fighting against the output driver going into it from the MAX232 pin 12, which is not a good idea.· You should never have an output directly connected to another output without being able to disable it or having a resistor in there for current protection.
Chris Savage
Stephan S
