ink pc to Parallax Servo Controller (Serial) — Parallax Forums
stepschstepsch Posts: 5
edited 2007-03-20 17:08 in Robotics
Hello,
·I have a new Parallax Servo Controller (Serial). Is it possible to connect the pc serial port 232(rx and tx) to a pin serial I/O of my Parallax Servo Controller? With a max232 ? Have you a shematic or document how explains to do that ?·
Thank for advance. Stéphane Schittek.
    edited 2007-03-16 14:42
    Apparently Parallax will be posting some schematics in the next few days for this. Have a look at this thread: http://forums.parallax.com/showthread.php?p=638357
    edited 2007-03-16 17:10
    Please check the Completed Projects Forum late Sunday (I will be posting these through the day on Saturday). Take care.
  • stepschstepsch Posts: 5
    edited 2007-03-20 15:17
    I tested a diagram which functions very well. See the diagram joint.
    Stephan S.
    1024 x 768 - 79K
    edited 2007-03-20 16:22
    The following attachment is the schematic that will be posted to the forums...
    edited 2007-03-20 16:36
    Thank you very much Chris.
    St
    edited 2007-03-20 17:01
    stepsch said...
    Stephan S.
    Hello,
    ·· The problem I see with your schematic is that when the Servo Controller is sending data back it is fighting against the output driver going into it from the MAX232 pin 12, which is not a good idea.· You should never have an output directly connected to another output without being able to disable it or having a resistor in there for current protection.
    Absolutely. My diagram is bad.
    Stephan S
