Parallx GPS module and BS2P24
I'm trying to test my Parallax GPS receiver module with the BS2P24 chip with the demo code provided online.·I'm using·"the Board of Education" to do the interfacing. After several tries, I was unable to retrieve any GPS coordinates although the red light was solid after blinking. The error message was: "Error: No response from GPS Receiver Module." I tried the baud rate at 500 and 4800 with the same results. Any help will be greatly appreciated. The code is·attached.·
Also, I would like to know how to operate in RAW mode.·Do·I connect the·/RAW pin to ground and SIO to the BS2p24? Thanks
Post Edited (guru1) : 3/14/2007 7:51:48 PM GMT
It's Only A Stupid Question If You Have Not Googled It First!!
Chris Savage
Parallax Tech Support
Chris Savage
