LEGO = PING ? I'm still workin with it...
Well I ran a ' PING_Demo.bs2 ' program while I poke the differnt wires in. This lego ultrasonic sensor's got 6 wires! Can I wire it up to work like the PING? Throw me som more suggestions. Thx.
MIKE
MIKE
http://mindstorms.lego.com/Overview/NXTreme.aspx
Jeff T.
MIKE
good luck
Jeff T.
http://forums.parallax.com/showthread.php?p=627189
Chris Savage
Parallax Tech Support
MIKE
The board will either be labeled or the pins could be identified by looking at the socket inside and comparing it to this.
cache.lego.com/upload/contentTemplating/MindstormsOverview/otherfiles/2057/LEGO%20MINDSTORMS%20NXT%20Hardware%20Developer%20Kit(3)_7A0CF630-CCE5-4AAF-91FA-D1E7C911817C.zip
The document that you need to look at in there is called:
Appendix 6-LEGO MINDSTORMS NXT Ultrasonic Sensor hardware schematic.pdf
