Robot charging station
Heres some photos of my new robot charging station.(this also powers my hobby shop).I am going to be adding more solar as I can afford it.
Thank's Brian
www.truckwiz.com
·"Imagination is more important than knowledge..." ·· Albert Einstein
Thank's Brian
www.truckwiz.com
I'm working on a project close to your a prop super-bot i just recevied my prop dev board a few weeks back , my first super bot use a bs2p40&Bs2p24 i didnt want to brake it down to use the prop so stated to construct a totaly new bot with the prop dev board (dreaming of a two prop syatem).
?. can you post your hb-25/ping romming code as seen on U-tube Demo . I new to spin and this would make a good getting stated example .
may be later i could send you more info on my project ideas .
ie. four pings
six I/R rangers
xbee como
i/p cam
pink
vdrive
cucam2+ for tracking
gps
temp humidity
lcd display
and two arms using five stepper motoers each
two hb-25 (not sure on using two wheel or four wheel drive system
this should be able to carry a 150lbs to 200lbs payload ( or beable to pull the same payload)
and thats just for starters there are a few more items left to add.
so anyHelp getting wint this prop would br great
thanks al-spider
·Sounds like your building the match to my robot, I'm working on making the ping look back and forth now, will be adding a cmu-cam , xbee, gps and lcd as I go. Will be happy to share code with you. :- )
p.s I'll post the code for the ping roaming when I get to my other computer.
Thank's Brian
www.truckwiz.com
Thank's Brian
www.truckwiz.com
Post Edited (Brian Beckius) : 3/11/2007 7:01:56 PM GMT
Does any body know of a good source for batteries for solar/wind . I grabed some truck batteries from the shop ( I know your not suppose to use normal 12 volts) . They seem to get harder to recharge every day .
Thank's Brian
www.truckwiz.com
The best type of lead-acid battery for solar/wind is a deep discharge sealed type. Optima makes a variety of such batteries and Batteries Plus does sell them and has outlets all over. I've used their starter batteries (red-top) for my car and have been pleased with it. I've also used their deep discharge batteries (blue-top) for running an inverter and low voltage lights where it would be charged up once a week from an AC charger or a wind turbine, then run all week with a low current load and briefly with a high current load. Worked well.
Starter type batteries are simply not designed for this kind of use (and don't work well at it).
Thank's Brian
www.truckwiz.com
