"swamp thing"
Here's a teaser picture
Thank's Brian
www.truckwiz.com
·"Imagination is more important than knowledge..." ·· Albert Einstein
Post Edited (Brian Beckius) : 2/27/2007 5:53:44 PM GMT
Thank's Brian
www.truckwiz.com
Alright! Cool! Another gas-powered robot. We have an interest in common.
What are you going to do with the rotational force of that Honda engine?
I should have a teaser picture to post in this thread by Sunday, too [noparse]:)[/noparse]
This forum have given me more gray hair , Everytime I think I'm sneaking ahead a little bit sombudy post somthing way better
P.S. I'm turning the motor sideways
Thank's Brian
www.truckwiz.com
Aha. Sideways.
Sounds like a forward-only robot with break steering on either side! If you're doing something like this then your robot will be on a high-speed trip . . . somewhere! Heck, my snowmobile only goes forward. Just keep me wondering.
And keep going with the project. Let me know if you need any hardware. I appreciate folks like you that put gas engines on their robots. You're ahead of your time.
I can see that you have access to a CNC machine of some type. Hmm.
Heres what our newest CAD software looks like
p.s. cardboard aided design
Thank's Brian
www.truckwiz.com
Reminds me of when the boss wanted me to make LPKF (CNC Mill) pcbs of one of our old designs. I said "no problem". Then he gave me a piece of vellum with layers of thin black tape on it. I'm like "What the heck (I didn't say heck either) I'm I supposed to do with this?".
Bean.
Cheap used 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
SX-Video Display Modules www.sxvm.com
p.s. hyd motor photo
Thank's Brian
www.truckwiz.com
Post Edited (Brian Beckius) : 2/23/2007 8:43:16 PM GMT
A couple things I would like to point out. First I would like to thank you for the inspiration to build a gas powered robot (after I seen your hybrid, I knew I needed one). Second, I can tell that from the parts that I’ve purchased so far that parallax’s R&D robot is going to be a steal at around $2000 .
ps . I'm working on the track drive system , and I'll post photo's when I get the bugs worked out.
Thank's Brian
www.truckwiz.com
Just give us a little peek
Thank's Brian
www.truckwiz.com
I don't work at parallax , I'm a truck mechanic by day and a microcontroller robot geek at night. I've allways said that if you enjoy doing somthing sucess will follow. If you have somthing you love doing , learn all that you can , ask questions and then invent something that will make you the next Bill·G. or Chip G.·!
Thank's Brian
www.truckwiz.com
Post Edited (Brian Beckius) : 2/28/2007 3:53:34 PM GMT
P.s. Just converted my hobby shop to solar , blew up the first inverter. I'll start over.
Thank's Brian
www.truckwiz.com
Post Edited (Brian Beckius) : 3/5/2007 4:56:00 AM GMT
http://www.teamkiss.com/kiss2.htm
We didn't use a micro controller to drive this thing with. But we did hack together a gasoline powered RC-ROV with some very very used parts... This very crude·machine actually had forward/reverse using a manual tractor transmission. There is a way to create true skid steer using belt drives, by the way. And you can slam full forwad and full reverse without having to come to a full stop and shift gears. Engine driven·counter rotating shafts driving belts and pulleys·provide the FWD/REV clutching action.·I've been wanting to do it for several years now but funding has always been a problem for my Team's. Of course there are some·modern hydrostatic gear boxes/transaxles·available that would probably solve that problem nicely as well. And they would be easy to control with a BASIC Stamp2 or RC or a combination of both.. Good Luck with your project. It looks great!
Team K.I.S.S
Build Safe, Build Mean, Build Strong!
Post Edited (slamer) : 3/5/2007 7:17:11 PM GMT
