BS2pe Identification Problem
I am having a serious issue ( To me atleast)!! I just purchased a BS2PE and a BOE went step by step with the instructions and when i got to identify it gets a good loop back and echo but doesn't show the device type or version. So when i try to tun a program it tells me No basic Stamps found. I do have the most current version of the stamp editor 2.2.6 and have tried hooking this up on two differnt pc's with differnt operation systems xp pro and server 2003 enterprise. any help will be appreciated.[noparse][[/noparse]Subject Changed By Moderator]
Post Edited By Moderator (Chris Savage (Parallax)) : 2/21/2007 3:29:41 PM GMT
I take it that this is a serial connection BOE ?
Check·Stamp is orientation in the Socket ?
'Necessity is the mother of invention'
Post Edited (QuattroRS4) : 2/21/2007 3:03:28 AM GMT
For me the power supply I was using was variable and was not set on the right voltage. It was set on 3V and while the power LED ont he board lighted up this voltage is not sufficient to power the Stamp.
See here for Power Supply Details:
[noparse][[/noparse]http://www.parallax.com/html_pages/tech/faqs/gnrl_info.asp#Power the Stamp]
Also if you are using the USB cable make sure to download and run the USB driver.
What PSU are you using ?
Note: Correct driver installation is handled through a live Internet connection when using Win XP.
Just getting back to basics here ...
You Installed the driver first and then connected the Device - correct ?
or just do Ctrl+I
The latest version of drivers are on the Parallax Website -
Why do you think the stamp may be bad ?
Did something happen before you were unable to connect ?
You are sure 1) Battery is good
2) PSU is good
When the device is connected
is the URL you requested -
I think after that its tech Support - My opinion after all that - it is a dead·Stamp - I hope I am wrong and it it something fundamental·- keep us posted...
Quattro
Is this a pure USB setup or is there a USB to serial adapter in this configuration of yours?
Bruce Bates
<!--StartFragment -->
Because not all adapters will work. And the FTDI drivers require you to have an FTDI-based USB to Serial adapter if that's going to work.
Edit:· Oh, dear, I just got that you DO have·a "USB BOE" board, which DOES use the FTDI chips, so there IS no USB to serial adapter (other than the one embedded on the BOE board).· Is this correct?
http://www.parallax.com/html_pages/downloads/software/ftdi_drivers.asp
Chris Savage
Parallax Tech Support
Post Edited (Chris Savage (Parallax)) : 2/21/2007 3:27:51 PM GMT
You got sorted then - and it was the stamp? - I noticed your 'Post of Praise' - I have to say that it unlikely that you would ever find such support or interest from another company - which is probably why the forums are so active .... enjoy..
Quattro
Post Edited (QuattroRS4) : 2/23/2007 4:50:54 PM GMT
