Help File Version vs. SX/B Version [ANALOGIN command]
Zoot
I just received my SX-Key and some SX-28s and have been playing around. Everything works great, except I've got a question about the online SX/B help file.
SX/B as I downloaded and installed it is version 1.51.03 (Sept. 06 -- the most recent version according the sticky at the forum). But the online help file is version 1.51.01 (July 06). Is this right? Is there a more current help file? Does it matter?
Post Edited By Moderator (Bean (Hitt Consulting)) : 2/20/2007 7:01:49 PM GMT
That is the latest help file. The changes from 1.51.01 to 1.51.03 are just bug fixes.
Oh and 1 new command ANALOGIN.
Bean.
Cheap used 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
SX-Video Display Modules www.sxvm.com
Stuff I'm selling on ebay http://search.ebay.com/_W0QQsassZhittconsultingQQhtZ-1
"USA Today has come out with a new survey - apparently, three out of every four people make up 75% of the population." - David Letterman
Chris
· Give a bit of time and I'll make a document to explain the ANALOGIN command.
· I should have done it earlier.
· This page explains how to connect it. http://www.sxlist.com/techref/scenix/lib/io/adc_vp.htm
Bean.
Chris
· Here is a preliminary copy of the document. It still needs some work, but I wanted to get something to you ASAP.
[noparse][[/noparse]edit] I see a bunch of typos. Comments welcome...
Bean.
Post Edited (Bean (Hitt Consulting)) : 2/21/2007 3:14:33 AM GMT
Thanks for getting that together.· I should be able to get through it tomorrow and I will send you any edits that I find.·
Chris
Comment welcome...
Bean.
