Help File Version vs. SX/B Version [ANALOGIN command] — Parallax Forums
ZootZoot Posts: 2,227
edited 2007-02-21 03:11 in General Discussion
I just received my SX-Key and some SX-28s and have been playing around. Everything works great, except I've got a question about the online SX/B help file.
SX/B as I downloaded and installed it is version 1.51.03 (Sept. 06 -- the most recent version according the sticky at the forum). But the online help file is version 1.51.01 (July 06). Is this right? Is there a more current help file? Does it matter?
Post Edited By Moderator (Bean (Hitt Consulting)) : 2/20/2007 7:01:49 PM GMT
  • BeanBean Posts: 8,129
    edited 2007-02-18 16:33
    Zoot,
    That is the latest help file. The changes from 1.51.01 to 1.51.03 are just bug fixes.
    Oh and 1 new command ANALOGIN.
    Bean.
    Stuff I'm selling on ebay http://search.ebay.com/_W0QQsassZhittconsultingQQhtZ-1
    "USA Today has come out with a new survey - apparently, three out of every four people make up 75% of the population." - David Letterman
  • sealion99sealion99 Posts: 23
    edited 2007-02-18 16:44
    How is the ANALOGIN command used?· What parameters does it take?
    Chris
    edited 2007-02-19 22:01
    Chris,
    · Give a bit of time and I'll make a document to explain the ANALOGIN command.
    · I should have done it earlier.
    · This page explains how to connect it. http://www.sxlist.com/techref/scenix/lib/io/adc_vp.htm
    Bean.
    edited 2007-02-20 10:31
    Thanks.· That would be great!· Could you e-mail me a copy of whatever you put together once it is done?· I appreciate your help.
    Chris
    edited 2007-02-20 18:59
    Chris,
    · Here is a preliminary copy of the document. It still needs some work, but I wanted to get something to you ASAP.
    [noparse][[/noparse]edit] I see a bunch of typos. Comments welcome...
    Bean.
    Post Edited (Bean (Hitt Consulting)) : 2/21/2007 3:14:33 AM GMT
    edited 2007-02-21 01:32
    Hi Bean,
    Thanks for getting that together.· I should be able to get through it tomorrow and I will send you any edits that I find.·
    Chris
    I did some more work on the document explaining the SX/B ANALOGIN·command.
    Comment welcome...
    Bean.
