Defect Protoboard
Received 5 of the new protoboard.
1 seems to be defect?
Found out by running the blink object and attached a LED to one pin at a time.
On the defect board no light the other 4 gave light.
Measured with an Ohmmeter towards GND on a couple of pins, both + and - ,nearly the same reading as a non defect board.
When loading the blink object it looked OK, the IDE did not give any error, loading the eeprom and verification OK
Power both 3.3V and 5V is OK.
Current same as a non defect board.
Tried swap the crystal.
Result, all pins seems dead.
Any other test I can perform?
Paul Baker
I tested as instructed.
When all pins was set as outputs and high, only pin 28-29-30-31 read 3.3V the rest 0V
When all pins was set as outputs and·low, pin 28-29-30-31 read 3.3V and the rest 0V
Goran (Sweden)
Paul Baker
This is what i used:
I also verified the test on one of the OK protobords
Test 1______________________________________________________
CON
· _CLKMODE = XTAL1 + PLL4X···· 'Set to ext low-speed crystal, 4x PLL
· _XINFREQ = 5_000_000········ 'Frequency on XIN pin is 5 MHz
PUB Main
· dira[noparse][[/noparse]0..31]~~
· repeat
··· outa[noparse][[/noparse]0..31]~
Test 2______________________________________________________
CON
PUB Main
· repeat
··· outa[noparse][[/noparse]0..31]~~
Regards, Goran
It sounds like you are able to download to it, but no program runs.
Try removing the _CLKMODE and _CLKFREQ constants so the chip will run using the internal 12MHz oscillator, instead of using the crystal.
If that works, then there is something wrong with the oscillator. Perhaps the crystal is bad or there is some problem with the crystal connection.
Does it appear that the Propeller chip has any unsoldered pins?
Chip
Chip Gracey
When set to low I had the USB Propplug attached. when removed it was only Pin 29-29 that was high.
Regards Goran
Paul Baker
I have checked the soldering·or shortage of all pins
I have already tried this:
PUB Main
· repeat
PUB Main
· repeat
Regards, Goran
Paul Baker
I mail you the contact info.
Regards, Goran
Try running this program:
CON pin = 0
PUB toggle
· dira[noparse][[/noparse]pin] := 1
· repeat
····· !outa[noparse][[/noparse]pin]
You can change pin from 0 to 31.
I think some pin(s) might be shorted to VSS or VDD and when made outputs, they draw enough current to cause a brownout reset.
The fact that you can download to the board says that the Propeller chip is alive, and able to control at least P31 and P30.
If you find a culprit pin, check it for a short. It could be from soldering, or from a hair-line PCB trace that shouldn't be there.
Chip Gracey
Sorry for not answer direct, had to sleep a bit. Be aware of the time in Sweden
I tried setting all the pins to high, one by one as instructed.
All read low exept 28 and 29 which read high all the time.
As in earlier respond I also measured all pins with an ohmmeter, no shortage found.
Also compared with a working card swapping the ohmmeter from + to - and the reading on all pins where nearly equal as the working card.
Conclusion, could not be anything outside the Propchip causing the problem??? or?
Regards, Goran
It is true that you can download to it, right? Can you do an F7 and get the chip version, also?
Chip Gracey
Yes a can download both with F10 and F11.
Verifing eeprom works OK.
Doing F7 it reports "Chip Version 1 found on com 14".
I can not understand whats wrong with the protobord·, everything when programming seems OK.
For your Info, I have played with the propeller for a while now.
I have in my lab·1 demoboard, one propstick, one Propeller Education Kit ,
4 P8X32A-D40 (40-pin DIP) chip·
,2 P8X32A-Q44 (44-pin QFP) chip
and·2 by me made protoboard one with QFP and one with DIP40.
All of these have worked whitout problem for 2 months.
Regards, Goran
<!-- unit price -->
Another problem is the broadcast.
I have tried all tips and tricks in this forum but are not able to get a broadcast signal that works with PAL, which is the only system I can use.
This is one of the setups I tried:
tvparams············long··· 0·············· 'status
······················· long··· 1·············· 'enable
······················· long··· %001_0101······ 'pins
······················· long··· %0011·········· 'mode
······················· long··· 0·············· 'screen
······················· long··· 0·············· 'colors
······················· long··· x_tiles········ 'hc
······················· long··· y_tiles········ 'vc
······················· long··· 10············· 'hx
······················· long··· 1·············· 'vx
······················· long··· 0·············· 'ho
······················· long··· 0·············· 'vo
······················· long··· 55_250_000·············· 'broadcast
······················· long··· 1·············· 'auralcog
Regards, Goran
Chip Gracey
Now I have broadcast on near CH 4
Thanks, Goran
