non contact temp sensor
I am working on a project to monitor the temperature of an elevator brake drum.· Since the drum rotates, I cannot mount the sensor to the drum.· I want to have two temp. set points, one to stop the car at the next floor, and if for some reason the temps continue to rise the second would make a emergency shut down.· Sorry if this info has been posted before, but can someone recomend a suitable IR sensor?
optoelectronics.perkinelmer.com/catalog/Category.aspx?CategoryName=Thermopiles
- Stephen
Scott
