GPS Time Converted to Video Timecode?
Hello,
I need to convert the information that is sent every second from the GPS receiver into video timecode which divides seconds into increments of 1/30th of a second. I will be using the information to timestamp events that occur live so that they can be edited into video later. But, I need more precision than just 1 second. If any of you can direct me in the right direction, I would sure appreciate it.
DH
DH
www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
From what I can determine, you may not get an accurate one second pulse. There's a whole data stream coming in with all kinds of information depending on what satellites are visible and the current time/date is just one packet of information and may be delayed by other information queued for serial transmission. I would not try to reset the timer based on the presence of serial data. As I described, I'd look at the actual time and use it to adjust the 1/30 second clock.
It all depends on the time sources of your camera and sound equipment. (usually not very good). That's why they use a time burst, either cabled or wireless.
If you don't mind having to hand tweek it, here's what I do:
1. Set the camera to 'free run'. The frame clock is always running even when not recording.
2. Set the clock to time of day. Careful if your shoot is going to continue through midnight. Most editor software burp on the time code jumping back to 00:00:00. So if you start shooting a 10:00pm, set it to 10:00am.
3. Get all cameras, sound recorders and your wristwatch etc, and (with their remotes if possible) set them to the same time.
4. If you cheapo sound recorders are like mine, they won't time stamp the files. You or the boomperson, will have to read their watch and announce the time at the start of each take. You'll have to listen to the first few seconds of the file and change filename to start time code.
Gotya's :
-The time sources in the cameras will drift. You may have to re-sync at the lunch break. It only takes a minute or two.
-They might will be good all day. Mine are.
-You (the editor) will still have to hand sync.
-If one single take is longer than 10 to 15 minutes (depending on the clocks), your video may be longer or shorter by a number of frames. Now you have a audio file that doesn't match you video, being X number of frames off at the end. Your audio/video software can correct this with no problem. I have shot for 20 minutes (a very long take for me) and wasn't off but about one frame. (we didn't adjust it). It's the luck of the draw. I've heard of guys being out at ten minutes and others shooting for 30 with no problems.
-Battery changes in some cameras, RESET the clocks or stop 'free run'.
How do you plan on recording the timecode? Remember if you're going to record LTC or any type of sync pulse to an audio channel, keep it low so it doesn't bleed over.
IF you are using pro cameras and equipment, things are somewhat different than explained. (easier). Their motors are controlled by the clock. We're stuck with free running motors/circuits (mine are solid state) and recording timestamps. Even if you get a nice signal out from the GPS, it may or may not be in sync with the camera.
And lastly, the Parallax GPS unit does not send a pps. I've been playing ... er working with it lately.
HTH, Chris
Post Edited (CCraig) : 2/15/2007 3:20:56 PM GMT
