QTI location
I am building a Linefollower. I have one caster in the front and two independent drive wheels in the back. I currently have there QTI sensors located along the rear drive axel. Is there a better location, if so, where is the best placement for the sensors?
thanks for the help
Josh
Magic Smoke Theory of Electronics –
Inside every electronic part there is magic smoke.
The magic smoke is what makes everything work.
If you release the magic smoke, the part stops working!
thanks for the help
Josh
- Stephen
