QTI location — Parallax Forums
QTI location
Mr. RichardMr. Richard Posts: 51
edited 2007-02-12 19:09 in General Discussion
I am building a Linefollower. I have one caster in the front and two independent drive wheels in the back. I currently have there QTI sensors located along the rear drive axel. Is there a better location, if so, where is the best placement for the sensors?
thanks for the help
Josh
Magic Smoke Theory of Electronics –
Inside every electronic part there is magic smoke.
The magic smoke is what makes everything work.
If you release the magic smoke, the part stops working!
  • Steve JoblinSteve Joblin Posts: 784
    edited 2007-02-12 13:30
    I may be mistaken, but shouldn't the line sensor be mounted as far front as possible... you want to "see" where you are going, not where you are...
    I would also put the drive in the front and the caster in the back.
    - Stephen
