Boe-Bot - no power light
Greetings all.· Last year I purchased the Board of Education from the Geeks, but due to "issues" (such as no time at all!) I was unable to play with it.· I ordered the usb adapter since none of my machines have a serial port anymore, loaded the drivers, put in a fresh set of batteries, plugged everything in (double checking the IC positions etc etc before applying power ) and switched to position 1 from 0, and ... nothing. no green light, nada. Does the BOE need 9 volts to run? Seems like it should power up with 6 according to the docs.· I metered the battery pack at over 6v. so now what?
Thanks for any help
Eric
Thanks for any help
Eric
- Stephen
Post Edited (codpilot) : 2/4/2007 2:11:39 AM GMT
1. clean your connections with a lens cloth (dry).
2. swap out your BS2 with another one.
3. swap out your BOE with another one.
Shameless plug:
I've answered your question, please answer my question
[noparse][[/noparse]urlhttp://forums.parallax.com/forums/default.aspx?f=5&m=169849
I don't have a spare BS2 or BOE (yet).· I'll start my tracing Friday night (I teach until 10 tonight and until 5 on friday 8( )
Thanks· for the ideas though - the hunt continues!
I recieved one from them AND it was mis-wired. I un-soldered it from the battery pack, soldered it correctly and away it goes.
HTH, Chris
