Boe-Bot - no power light — Parallax Forums
codpilotcodpilot Posts: 4
edited 2007-02-08 14:43 in Robotics
Greetings all.· Last year I purchased the Board of Education from the Geeks, but due to "issues" (such as no time at all!) I was unable to play with it.· I ordered the usb adapter since none of my machines have a serial port anymore, loaded the drivers, put in a fresh set of batteries, plugged everything in (double checking the IC positions etc etc before applying power ) and switched to position 1 from 0, and ... nothing. no green light, nada. Does the BOE need 9 volts to run? Seems like it should power up with 6 according to the docs.· I metered the battery pack at over 6v. so now what?
Thanks for any help
Eric
    edited 2007-02-03 23:27
    Check all your wiring and connections. Mine powers up with a green led with four month old AA batterys. Don't connect anything to the bot (no usb no servos, nothing and see if you get a light. Check the polarity of the led. Let us know what you find.
    - Stephen
  • codpilotcodpilot Posts: 4
    edited 2007-02-04 01:37
    As of right now the board is empty, no servos, no wirers nothing but the bare board and a BS2. The LED is soldered so close I can't see the· polarity (factory assembled and all that). Not a whole lot of other wires and connections to check (one serial usb connector and one plug from the battery pack). so I'm a little stumped.
    Post Edited (codpilot) : 2/4/2007 2:11:39 AM GMT
  • latigerlillylatigerlilly Posts: 114
    edited 2007-02-05 15:02
    Try to isolate your problem. Is it the BOE, the BS2, or the connection?
    1. clean your connections with a lens cloth (dry).
    2. swap out your BS2 with another one.
    3. swap out your BOE with another one.
    Shameless plug:
    [noparse][[/noparse]urlhttp://forums.parallax.com/forums/default.aspx?f=5&m=169849
    edited 2007-02-08 13:30
    Sorry for the delay in response, but I teach (7 classes this semester - leaves me only weekends to play with the fun stuff) but so far the power is getting to the board, and to the voltage regulator.· I checked the bs2 chip, all pins are good , I'll download the schematics and do a trace of the power.· My led is right on the board and not very clear (shower stall opaque so to speak) so I need to find my magnifier and see what I can see.
    I don't have a spare BS2 or BOE (yet).· I'll start my tracing Friday night (I teach until 10 tonight and until 5 on friday 8( )
    Thanks· for the ideas though - the hunt continues!
  • CCraigCCraig Posts: 163
    Make sure the power cable is wired correctly.
    I recieved one from them AND it was mis-wired. I un-soldered it from the battery pack, soldered it correctly and away it goes.
    HTH, Chris
